[GRASS-dev] [GRASS GIS] #1861: v.net.distance should exclude path to self
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: network distance | Platform: Unspecified
      Cpu: Unspecified |
When using v.net.distance in grass7, giving it all the available nodes as
from and to nodes, the result is a series of zero length paths from each
node to itself. v.net.distance should skip paths to self and chose the
closest node amongst the remaining set of nodes.
To reproduce:
v.net roadsmajor points=schools_wake op=connect thresh=500 out=network --o
["thresh" should probably be renamed to "threshold" for consistency]
v.net.distance network out=paths from_layer=2 from_cats=1-999 to_layer=2
to_cats=1-999 --o
[from_layer and to_layer should probably be 2 by default]
v.db.select paths
cat|tcat|dist
7|7|0
8|8|0
9|9|0
28|28|0
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1861&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [ticket:1861 mlennert]:
as from and to nodes, the result is a series of zero length paths from
each node to itself. v.net.distance should skip paths to self and chose
the closest node amongst the remaining set of nodes.
Technically, this is possible and actually not very difficult, but it
would require to rewrite v.net.distance from scratch.
Currently, the module starts with all 'to' nodes and calculates the
shortest path of all nodes to all 'to' nodes. Then the module iterates
through the 'from' nodes and finds for each 'from' node the nearest 'to'
node. At this point it is too late to exclude paths to self because that
is the only path computed.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1861#comment:1&gt;
      Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:1 mmetz]:
Ok, then I'll just add a hint to the man page indicating that from and to
nodes should be different. One can always use v.net.allpairs to get the
same info with a bit of postprocess data massaging.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1861#comment:2&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: network distance
  Platform: Unspecified | Cpu: Unspecified
Changes (by mlennert):
  * status: new => closed
  * resolution: => wontfix
Comment:
Replying to [comment:2 mlennert]:
nodes as from and to nodes, the result is a series of zero length paths
from each node to itself. v.net.distance should skip paths to self and
chose the closest node amongst the remaining set of nodes.
to nodes should be different.
Done in all branches.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1861#comment:3&gt;
