[GRASS-dev] [GRASS GIS] #1862: Corrections GRASS 7.0 help files db.connect and v.db.connect
Reporter: pvanbosgeo | Owner: grass-dev@…
     Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
In db.connect, it is suggested the default driver is dbf
For both db.connect and v.db.connect the default database name is said to
be $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
This is obviously not a defect, but there does not seem to be a 'ticket
type' that fits the bill in this case. Perhaps one can added for reports
about issues in the help files / documentation?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1862&gt;
Component: Docs | Version: svn-trunk
      Cpu: Unspecified |
Changes (by neteler):
  * component: Default => Docs
Ticket URL: <http://trac.osgeo.org/grass/ticket/1862#comment:1&gt;
      Cpu: Unspecified |
Comment(by neteler):
The "docs" tag is there. The following manual pages may need an update to
SQLite:
  * db.columns/db.columns.html
  * db.connect/db.connect.html
  * db.copy/db.copy.html
  * db.describe/db.describe.html
  * db.tables/db.tables.html
Patches appreciated :slight_smile:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1862#comment:2&gt;
Ah, OK, had overlooked that component tag, that is what happens when trying to file a ticket quickly in between other tasks :-/ . Anyway, good to know for next time. I guess even patches for the manual pages require some serious programming background… otherwise I would have been happy to provide them.
Cpu: Unspecified |
The “docs” tag is there. The following manual pages may need an update to
SQLite:
  • db.columns/db.columns.html
  • db.connect/db.connect.html
  • db.copy/db.copy.html
  • db.describe/db.describe.html
  • db.tables/db.tables.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/1862#comment:2>
Hi Paulo,
not at all. You may post the change suggestions even as email and
we'll merge them in manually, not too much work in this case.
I just don't manage to write the better examples myself in this period.
Hi Markus,
OK, as an example, in db.connect, the ‘offending’ text is under the ‘Parameter’ heading. The default driver name and the default database name should change (marked with >>):
On Fri, Jan 25, 2013 at 9:31 AM, Paulo van Breugel
<p.vanbreugel@gmail.com> wrote:
Hi Markus,
OK, as an example, in db.connect, the 'offending' text is under the
'Parameter' heading. The default driver name and the default database name
driver=name
   Name of database driver
   Options: pg, odbc, mysql, ogr, dbf, sqlite
   >> Default: sqlite
database=name
   Name of database
   >> Default: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
schema=name
   Database schema
   Do not use this option if schemas are not supported by driver/database
server
group=string
   Default group of database users to which select privilege is granted
Just for my understanding, these parts of the manual page are not in the
html file
(http://svn.osgeo.org/grass/grass/trunk/db/db.connect/db.connect.html) and
I
assume they are generated / parsed from the actual code? With no
understanding of the source code (I had a look out of curiosity, but that
was an exercise in futility), I was wondering how/if I could suggest
changes
that would actually be more helpful then just mentioning them like above.
I think the demolocation in the source tree needs to be changed to
sqlite, because db.connect and v.db.connect use
db_get_default_*_name().
Markus M
Paulo
On Fri 25 Jan 2013 07:09:56 AM CET, Markus Neteler wrote:
Hi Paulo,
grass-dev mailing list
grass-dev@lists.osgeo.org
On Fri, Jan 25, 2013 at 9:50 AM, Markus Metz
Hi Markus,
driver=name
   >> Default: sqlite
database=name
   Name of database
schema=name
   Database schema
server
group=string
html file
I
changes
The demolocation adjusted for trunk in r54771. The manuals will be
updated after make distclean; configure; make.
Markus M
Paulo
Hi Paulo,
Keywords: | Platform: All
      Cpu: Unspecified |
  * platform: Unspecified => All
Comment:
db.connect improved in r55009
db.copy improved in r55011
Ticket URL: <http://trac.osgeo.org/grass/ticket/1862#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: All | Cpu: Unspecified
  * status: new => closed
  * resolution: => fixed
Comment:
Completed in r59358 and r59359. Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1862#comment:4&gt;
