[GRASS-dev] [GRASS GIS] #1865: WinGrass v.buffer memory issue
Reporter: feppink | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: 6.4.3 RCs
Keywords: | Platform: MSWindows 7
      Cpu: x86-64 |
System: Windows 7 64-bit Home Basic, GRASS 6.4.3-RC2, core i7 3612QM, 8Gb
RAM.
I have a vector map with a 30,131 primitives and well over 700,000
vertices. I want to create buffers of 50,000 map units (meters) around the
centroids of the primitives. If I do this, memory usage of v.buffer
steadily creeps up and at some point GRASS runs out of memory and
terminates v.buffer.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1865&gt;
      Cpu: x86-64 |
Comment(by feppink):
Additional info: I specify no other options for v.buffer apart from the
units for the major axis. Memory issue starts occurring during "Breaking
boundaries".
Ticket URL: <http://trac.osgeo.org/grass/ticket/1865#comment:1&gt;
      Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:1 feppink]:
boundaries".
If possible, try GRASS 7, because v.buffer only works correctly in GRASS 7
and vector memory consumption is much less.
Can you make the input vector map available and post the exact command
used to calculate buffers?
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1865#comment:2&gt;
Priority: blocker | Milestone: 6.4.4
Keywords: v.buffer | Platform: MSWindows 7
      Cpu: x86-64 |
Changes (by neteler):
  * keywords: => v.buffer
  * priority: normal => blocker
  * milestone: 6.4.3 => 6.4.4
Comment:
See also #1464 (v.buffer needs to be compiled with GEOS support).
See also #1343
See also #2223
Ticket URL: <https://trac.osgeo.org/grass/ticket/1865#comment:3&gt;
      Cpu: x86-64 |
Comment(by neteler):
Replying to [ticket:1865 feppink]:
8Gb RAM.
Here Linux, GRASS 6.4.svn (r59970), 8 GB RAM.
I have made a test with the current v.buffer (which itself now uses GEOS),
no (more?) memory issues:
# buffer polygons
GRASS 6.4.4svn (eu_laea):~ > v.buffer clc2000_E45N25 out=buf distance=100
  100%
  100%
  100%
Breaking polygons...
  100%
  100%
Removing duplicates...
  100%
Breaking boundaries...
date%
  100%
  100%
Cleaning boundaries at nodes
  100%
Building topology for vector map <buf>...
Building areas...
  100%
200514 areas built
16651 isles built
Number of nodes: 239757
Number of primitives: 641559
Number of points: 0
Number of lines: 0
Number of boundaries: 641559
Number of centroids: 0
Number of areas: 200514
Number of isles: 16651
Number of areas without centroid: 200514
Removing dangles...
  100%
Removing bridges...
  100%
Attaching islands...
  100%
Number of points: 0
Number of lines: 0
Calculating centroids for all areas...
  100%
Generating list of boundaries to be deleted...
  100%
Deleting boundaries...
  100%
Calculating centroids for areas...
  100%
Registering primitives...
1479 primitives registered
10551 vertices registered
Building areas...
  100%
4 areas built
4 isles built
  100%
Attaching centroids...
  100%
Number of nodes: 1479
Number of primitives: 1479
Number of points: 0
Number of lines: 0
Number of boundaries: 1478
Number of centroids: 1
Number of areas: 4
Number of isles: 4
Number of areas without centroid: 3
And
# buffer centroids
GRASS 6.4.4svn (eu_laea):~ > v.buffer test out=buf2 distance=50
type=centroid
Buffering features...
  100%
Cleaning buffers...
Building parts of topology...
  100%
Number of nodes: 39266
Number of primitives: 39266
Number of points: 0
Number of lines: 0
Number of boundaries: 19674
Number of centroids: 19592
Number of areas: 19592
Number of isles: 19592
Please try again.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1865#comment:4&gt;
Priority: critical | Milestone: 6.4.4
      Cpu: x86-64 |
  * priority: blocker => critical
Ticket URL: <http://trac.osgeo.org/grass/ticket/1865#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.buffer
  Platform: MSWindows 7 | Cpu: x86-64
  * status: new => closed
  * resolution: => fixed
Comment:
No response on original issue for > 1 year, v.buffer is meanwhile based on
GEOS.
Closing, feel free to reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1865#comment:6&gt;
