GDAL
February 2, 2013, 5:45pm
1
#1869: wingrass7: r.in.wms - ERROR: Unable to load GDAL python bindings
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Component: Raster | Version: svn-trunk
Keywords: wingrass, r.in.wms, gdal, python | Platform: MSWindows 7
Cpu: x86-64 |
tested with some examples from the manual
r.in.wms url=http://irs.gis-lab.info layers=osm output=osm format=png
(Sat Feb 02 18:26:31 2013) Command finished (0 sec)
(Sat Feb 02 18:41:46 2013)
r.in.wms url=http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms
layers=bluemarble,landsat_1_01 styles=default,default output=landsat
srs=4326 format=png
(Sat Feb 02 18:41:46 2013) Command finished (0 sec)
tested with
GRASS version: 7.0.svn
GRASS SVN Revision: 54831
Build Date: 2013-02-02
GIS Library Revision: 52468 (2012-07-27)
GDAL/OGR: 1.9.2
PROJ.4: 4.8.0
GEOS: 3.3.6dev
SQLite: 3.7.10
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1869> ;
GRASS GIS <http://grass.osgeo.org >
Cpu: x86-64 |
srs=4326 format=png
tested with
GDAL/OGR: 1.9.2
PROJ.4: 4.8.0
GEOS: 3.3.6dev
SQLite: 3.7.10
Python: 2.7.2
wxPython: 2.8.12.1
Helmut, GDAL needs to be configured --with-python
HTH,
madi
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1869 >
grass-dev mailing list
grass-dev@lists.osgeo.org
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
hellik
February 2, 2013, 11:20pm
3
hi madi,
thanks for the hint!
before I ask at osgeo4w, which wingrass is based on, I've wanted to check if
there is any grass-related issue.
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/GRASS-GIS-1869-wingrass7-r-in-wms-ERROR-Unable-to-load-GDAL-python-bindings-tp5031663p5031707.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
On Sun, Feb 3, 2013 at 12:20 AM, Helmut Kudrnovsky <hellik@web.de > wrote:
hi madi,
before I ask at osgeo4w, which wingrass is based on, I’ve wanted to check if
Maybe it should be written somewhere in the GRASS manual (?) though, since AFAIK it’s not the default configuration of GDAL.
best regards
Helmut
Sent from the Grass - Dev mailing list archive at Nabble.com .
Margherita DI LEO
Via Fermi, 2749
On Sun, Feb 3, 2013 at 10:00 AM, Margherita Di Leo <dileomargherita@gmail.com > wrote:
hi madi,
I mean, * we should add it in the manual
best regards
Helmut
Margherita DI LEO
Via Fermi, 2749
Margherita DI LEO
Via Fermi, 2749
GDAL
February 3, 2013, 4:31pm
6
Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, r.in.wms, gdal, python
Platform: MSWindows 7 | Cpu: x86-64
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [ticket:1869 hellik]:
see http://lists.osgeo.org/pipermail/osgeo4w-dev/2013-February/002088.html
adding the osgeo4w-GDAL-python-bindings helps for this, for further r.in
.wms-issues in windows see:
http://trac.osgeo.org/grass/ticket/1872
closing ticket.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1869#comment:1> ;
hellik
February 3, 2013, 4:34pm
7
AFAIK it's not the
adding the GDAL-python-bindings in osgeo4w helps for this issue.
a short note in the manual would be nice.
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/GRASS-GIS-1869-wingrass7-r-in-wms-ERROR-Unable-to-load-GDAL-python-bindings-tp5031663p5031799.html
2013/2/3 Helmut Kudrnovsky <hellik@web.de>:
I have added this dependency for winGRASS7.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
