[GRASS-dev] [GRASS GIS] #187: CUPS warning when starting wxpython gui.
Reporter: brian | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone:
Component: Python | Version: svn-trunk
Keywords: wxpython g.gui |
CUPS PDF warning when starting wxpython gui.
Command: g.gui wxpython &
Warning:
** (brian:2966): WARNING **: Can't create printer "PDF" because the id
"PDF" is already used
(brian:2966): GnomePrintCupsPlugin-WARNING **: The CUPS printer PDF could
not be created
(brian:2966): GnomePrintCupsPlugin-WARNING **: The data for the CUPS
printer PDF could not be loaded.
System: Ubuntu 8.04 Python 2.5.2 wxPython 2.8.7.1
Ticket URL: <http://trac.osgeo.org/grass/ticket/187&gt;
  Priority: minor | Milestone: 6.4.0
Resolution: | Keywords: wxpython g.gui
Changes (by martinl):
  * milestone: => 6.4.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/187#comment:1&gt;
Component: wxGUI | Version: svn-trunk
  * component: Python => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/187#comment:2&gt;
  Platform: Linux | Cpu: x86-32
Changes (by brian):
  * platform: => Linux
  * cpu: => x86-32
Ticket URL: <http://trac.osgeo.org/grass/ticket/187#comment:3&gt;
Comment (by wlx):
also affected ubuntu intrepid, just because there is an exist "PDF" CUPS
printer, so you could remove the "PDF" printer in the printer manager, but
this is not a nice solution.
Ticket URL: <http://trac.osgeo.org/grass/ticket/187#comment:4&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: wxpython g.gui
Changes (by cmbarton):
  * status: new => closed
  * resolution: => wontfix
Comment:
This seems the same as ticket #205. There is extensive discussion and this
does not seem fixable. I'm closing both with a 'wontfix' label.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/187#comment:5&gt;
