#1872: r.in.wms doesn't work on Windows
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.in.wms | Platform: MSWindows 2K
Cpu: Unspecified |
Comment(by hamish):
it is worth re-testing since the script called from within another script
winggrass bug was recently fixed. that was for .bat wrappers in grass6
though, so may not apply to trunk.
also for locations using a grid file for the datum transform note the bug
that there is no way to pass the path to a NTv2 grid filename to cs2cs if
the path has a space in it, which can cause m.proj to fail. we should
probably submit a quoting patch to proj4 to get that eventually fixed.
... and a reminder that r.in.wms2.py does not run from grass6 addons,
still needs more porting work done on it.
Priority: major | Milestone: 7.0.0
Cpu: Unspecified |
Comment(by hamish):
I have not tested script-within-a-script in WinGrass7 or r.in.wms.py there
to see if m.proj is working with/without a NTv2 grid file, but afaik
issues as discussed in comment:3 remain.
Cpu: Unspecified |
Comment(by wenzeslaus):
In order to keep this ticket focused:
Note that ''script-within-a-scrip'' for standalone WinGRASS trunk is
subject of #2150 but a workaround is now applied. If this was the cause,
`r.in.wms` should work now.
Note also that whether ''`m.proj` is working with/without a NTv2 grid
file'' can test only somebody who understands what it is (e.g. I cannot
not). Is this MS Windows specific as this ticket is? Is this what the
message suggests? Perhaps the message should be changed to give more
details.
For GRASS 6, there is a separate ticket for `r.in.wms2`, #2010 and ticket #820 for `r.in.wms`.
