[GRASS-dev] [GRASS GIS] #188: MySQL driver: create table command cut
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: |
While copying all OSGeo NC data set vector maps from PERMANENT into a
"mysql" mapset, I got the following problem:
for i in `g.mlist type=vect map=PERMANENT` ; do
   echo "------ $i:"
   g.copy vect=$i,my$i
done
precip_30ynormals_3d:
Copy vector <precip_30ynormals_3d@PERMANENT> to current mapset as
<myprecip_30ynormals_3d>
DBMI-MySQL driver error:
Cannot create table:
CREATE TABLE myprecip_30ynormals_3d ( cat INTEGER, station DOUBLE, lat
DOUBLE, long DOUBLE, elev DOUBLE, jan DOUBLE, feb DOUBLE, mar DOUBLE, apr
DOUBLE, may DOUBLE, jun DOUBLE, jul DOUBLE, aug DOUBLE, sep DOUBLE, oct
DOUBLE, nov DOUBLE, dec DOUBLE, annual DOUBLE )
You have an error in your SQL syntax; check the manual that corresponds to
your MySQL server version for the right syntax to use near 'long DOUBLE,
elev DOUBLE, jan DOUBLE, feb DOUBLE, mar DOUBLE, apr DOUBLE, may DO' at
line 1
WARNING: Cannot create new table
Apparently the string is cut somewhere. I checked
db/drivers/mysql/create_table.c but could not find any reason.
Ticket URL: <http://trac.osgeo.org/grass/ticket/188&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords:
Changes (by marisn):
  * status: new => closed
  * resolution: => invalid
Comment:
LONG is MySQL datatype. Rename long column to anything else.
http://dev.mysql.com/doc/refman/5.0/en/blob.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/188#comment:1&gt;
