[GRASS-dev] [GRASS GIS] #1880: change color field to text for d.vect.chart
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Display | Version: 6.4.2 RCs
Keywords: d.vect.chart, color arguments | Platform: All
      Cpu: All |
The color argument for d.vect.chart is defined in such a way that the GUI
converts it to a color chooser (interactive way to select colors) for the
properties dialog in the layer manager.
The problem is that this field needs to accept MULTIPLE colors, not a
single color. This is where the colors for different data fields are
chosen so that they appear as different colors in the charts. A single
color chooser makes this useless.
So unless there is a way for a color chooser to create a list of colors,
this argument needs to be redefined as text that accepts a list of comma-
separated colors.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1880&gt;
Keywords: d.vect.chart, d.thematic.area, color arguments | Platform: All
      Cpu: All |
Changes (by hamish):
  * keywords: d.vect.chart, color arguments => d.vect.chart,
Comment:
The same is true for d.thematic.area, in devbr6 the gisprompt line has
been commented out with a note about it:
[browser:grass/branches/develbranch_6/display/d.thematic.area/main.c#L118]
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1880#comment:1&gt;
      Type: defect | Status: closed
Resolution: duplicate | Keywords: d.vect.chart, d.thematic.area, color arguments
  Platform: All | Cpu: All
Changes (by annakrat):
  * status: new => closed
  * resolution: => duplicate
Comment:
This is a duplicate of #1774 which has been fixed in 6.4 and 7 and now
also in 6.5 (r55845).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1880#comment:2&gt;
