#1884: grass7 - cairodriver fails to detect right architecture - OSX 10.8
Reporter: epifanio | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Keywords: cairo | Platform: MacOSX
Cpu: OSX/Intel |
Trying to build grass7 with cairo enabled, the build fails with the
following error :
epi:grass_trunk epi$ cd /usr/local/src/grass_trunk/lib/cairodriver
epi:cairodriver epi$ make
cc -dynamiclib -compatibility_version 7.0 -current_version 7.0
-install_name
/usr/local/grass-7.0.svn/lib/libgrass_cairodriver.7.0.svn.dylib -o
/usr/local/src/grass_trunk/dist.x86_64-apple-
darwin12.2.0/lib/libgrass_cairodriver.7.0.svn.dylib
-L/usr/local/src/grass_trunk/dist.x86_64-apple-darwin12.2.0/lib
OBJ.x86_64-apple-darwin12.2.0/Box.o OBJ.x86_64-apple-darwin12.2.0/Color.o
OBJ.x86_64-apple-darwin12.2.0/Draw.o OBJ.x86_64-apple-
darwin12.2.0/Draw_bitmap.o OBJ.x86_64-apple-darwin12.2.0/Driver.o
OBJ.x86_64-apple-darwin12.2.0/Erase.o OBJ.x86_64-apple-
darwin12.2.0/Graph.o OBJ.x86_64-apple-darwin12.2.0/Line_width.o OBJ.x86_64
-apple-darwin12.2.0/Raster.o OBJ.x86_64-apple-darwin12.2.0/Set_window.o
OBJ.x86_64-apple-darwin12.2.0/Text.o OBJ.x86_64-apple-darwin12.2.0/read.o
OBJ.x86_64-apple-darwin12.2.0/read_bmp.o OBJ.x86_64-apple-
darwin12.2.0/read_ppm.o OBJ.x86_64-apple-darwin12.2.0/read_xid.o
OBJ.x86_64-apple-darwin12.2.0/write.o OBJ.x86_64-apple-
darwin12.2.0/write_bmp.o OBJ.x86_64-apple-darwin12.2.0/write_ppm.o
OBJ.x86_64-apple-darwin12.2.0/write_xid.o -lgrass_driver.7.0.svn
-lgrass_gis.7.0.svn -L/usr/local/Cellar/cairo/1.12.12/lib -lcairo
-liconv
Undefined symbols for architecture x86_64:
"_FcConfigGetCurrent", referenced from:
_Cairo_set_font in Text.o
"_FcConfigSubstitute", referenced from:
"_FcDefaultSubstitute", referenced from:
"_FcFontList", referenced from:
_font_list_fc in Text.o
"_FcFontMatch", referenced from:
"_FcFontSetDestroy", referenced from:
"_FcInit", referenced from:
"_FcNameParse", referenced from:
"_FcObjectSetBuild", referenced from:
"_FcObjectSetDestroy", referenced from:
"_FcPatternCreate", referenced from:
"_FcPatternDestroy", referenced from:
"_FcPatternGetString", referenced from:
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see
invocation)
make: *** [/usr/local/src/grass_trunk/dist.x86_64-apple-
darwin12.2.0/lib/libgrass_cairodriver.7.0.svn.dylib] Error 1
this is not correct, the cairo lib installed on my machine are built as
universal in both arch 32 and 64 bit.
lipo -info /usr/local/Cellar/cairo/1.12.12/lib/cairo/libcairo-
trace.0.dylib /usr/local/Cellar/cairo/1.12.12/lib/libcairo-gobject.2.dylib
/usr/local/Cellar/cairo/1.12.12/lib/libcairo-script-interpreter.2.dylib
/usr/local/Cellar/cairo/1.12.12/lib/libcairo.2.dylib
Architectures in the fat file: /usr/local/Cellar/cairo/1.12.12/lib/cairo
/libcairo-trace.0.dylib are: i386 x86_64
/libcairo-gobject.2.dylib are: i386 x86_64
/libcairo-script-interpreter.2.dylib are: i386 x86_64
/usr/local/Cellar/cairo/1.12.12/lib/libcairo.2.dylib are: i386 x86_64
epi:~ epi$
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-cache: Mach-O universal
binary with 2 architectures
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-cache (for architecture i386):
Mach-O executable i386
x86_64): Mach-O 64-bit executable x86_64
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-cat: Mach-O universal
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-cat (for architecture i386):
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-cat (for architecture x86_64):
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-list: Mach-O universal
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-list (for architecture i386):
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-match: Mach-O universal
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-match (for architecture i386):
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-pattern: Mach-O universal
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-pattern (for architecture
i386): Mach-O executable i386
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-query: Mach-O universal
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-query (for architecture i386):
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-scan: Mach-O universal
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-scan (for architecture i386):
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-validate: Mach-O universal
/usr/local/Cellar/fontconfig/2.10.91/bin/fc-validate (for architecture
x86_64):Mach-O 64-bit executable x86_64
suspect :
seems that the GRASS Configure is not storing the fontconfig linking in
platform.make so it doesn't get into the cairo driver compilation.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1884>
