#1885: r.proj - from CELL to DCEL format
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: Unspecified |
When I reproject an raster layer in CELL format using nearest neighbor
assignment, the resulting output map is in DCELL.
Component: Raster | Version: svn-trunk
Keywords: r.proj | Platform: Linux
Cpu: Unspecified |
Comment(by pvanbosgeo):
That would indeed be no surprise :-).. But no, as mentioned in the
description, this is when using the nearest neighbor value, using an
integer map (CELL) as input.
