[GRASS-dev] [GRASS GIS] #1887: improve signal to noise ratio in the build logs
Reporter: hamish | Owner: grass-dev@…
Priority: normal | Milestone: 6.4.4
Component: Compiling | Version: svn-trunk
Keywords: make | Platform: Linux
      Cpu: x86-64 |
currently the build logs are highly cluttered with warning messages such
as:
Make/Grass.make:423: warning: overriding commands for target ...
Make/Grass.make:414: warning: ignoring old commands for target ...
Make/Script.make:47: warning: overriding commands for target `install'
Make/Rules.make:99: warning: ignoring old commands for target `install'
e.g. using the 6.4.3svn wxGUI g.extension.py to install an addon shell
script creates this output in the GUI output window:
Fetching <r3.in.xyz> from GRASS-Addons SVN (be patient)...
Compiling...
/home/hamish/dev/grass/svn/grass64svn/dist.i486-pc-linux-
gnu/include/Make/Grass.make:423: warning: overriding
commands for target `/home/hamish/grassdata/ll_wgs84/hb/.tmp
/debSqx86-vm/29440.0/r3.in.xyz/bin'
gnu/include/Make/Grass.make:414: warning: ignoring old
gnu/include/Make/Script.make:47: warning: overriding
gnu/include/Make/Rules.make:99: warning: ignoring old
/bin/sh: cannot create
gnu/locale/scriptstrings/r3.in.xyz_to_translate.c: Directory
nonexistent
sed: couldn't flush stdout: Broken pipe
Installing...
Updating metadata file...
Installation of <r3.in.xyz> successfully finished
but if you "grep -v 'warning: .* commands for target'" away the useless
warnings that gets reduced to this:
Compiling...
nonexistent
Installing...
... much more informative and you have a much better chance to spot any
real errors which may have happened along the way.
  * what does it mean?
  * if it is benign, can we make it go away without masking any real
problems?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1887&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:1887 hamish]:
> what does it mean?
It means that you have multiple rules (with commands) for a single target
(in this case, the "install" target). The last rule defined is used, any
others are ignored.
problems?
The "install" target in Rules.make recursively runs "make install" for
each directory in $(INSTALL_SUBDIRS). AFAICT, nothing ever sets that
variable, so the target is pointless.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1887#comment:1&gt;
      Cpu: x86-64 |
Comment(by hamish):
> > real problems?
Replying to [comment:1 glynn]:
> for each directory in $(INSTALL_SUBDIRS). AFAICT, nothing ever
> sets that variable, so the target is pointless.
see r38564, r38565. apparently it was for the i.pr/ collection of modules
in addons svn.
How to install groups of modules (like gipe or i.pr) using an automatic
download+compile tool like g.extension.* is still an open question.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1887#comment:2&gt;
Priority: normal | Milestone: 6.4.3
      Cpu: x86-64 |
Changes (by neteler):
  * milestone: 6.4.4 => 6.4.3
Comment:
Replying to [comment:2 hamish]:
modules in addons svn.
Since that fails anyway, these changes may be reverted.
Target back to 6.4.3
Ticket URL: <https://trac.osgeo.org/grass/ticket/1887#comment:3&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: make
  Platform: Linux | Cpu: x86-64
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
duplicate install target removed from devbr6 & relbr64 with r55249,
r55251.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1887#comment:4&gt;
