#189: WinGRASS installer can not find NC sampledata
Reporter: mloskot | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: default | Version: 6.3.0
Keywords: sample data north carolina |
During installation of WinGRASS 6.3.0 on Windows XP, I'm choosed to
install North Carolina sample data. The installer fails to find it with
error 404. See screenshot attached for the exact error message.
Note that I've not tried to install the other sample data package for
spearfish. Perhaps it also needs some fixes.
Component: Installation | Version: 6.3.0
Resolution: | Keywords: MS Windows, sample data north carolina
Comment (by marcopx):
Replying to [ticket:189 mloskot]:
Do you have any active firewall?
Please, in that case disable it (or allow the GRASS installer to access
the internet) and perform a new GRASS inatallation (you don't need to
uninstall it, just run the installer again)
Comment (by mloskot):
Marco,
I'm now connected to an open wireless network on university. I don't use
any antyvirus or thirdparty firewall software. I have disabled the default
firewall of Windows XP but it didn't help. I'm still getting the same
error. I hope it helps.
Comment (by neteler):
(Un)related to this: if you don't select any dataset to be installed it
starts with broken .gisrc6 file apparently (not sure how this file works
under Windows, at least the startup is blocked with a related message).
Replying to [comment:5 neteler]:
> Markus
No, on Windows it doesn't happen, because the installer creates a .gisrc6
file that "points" to the demolocation (installed in $DOCUMENTS/GIS
DataBase, as the others sample datasets, if selected)
Replying to [comment:4 mloskot]:
> Marco,
Replying to [comment:6 marcopx]:
it starts with broken .gisrc6 file apparently (not sure how this file
works under Windows, at least the startup is blocked with a related
message).
> > Markus
.gisrc6 file that "points" to the demolocation (installed in
$DOCUMENTS/GIS DataBase, as the others sample datasets, if selected)
> Marco
Sorry, misunderstanding: I read .grassrc6 instead of .gisrc6; AFAIK,
.gisrc6 is not used in WinGRASS,
Replying to [comment:7 marcopx]:
> OK. I found the bug.
> The installer downloads the NC sample data tarball from the following
http address: http://grass.osgeo.org/sampledata/nc_spm_07_2007_dec20.tar.gz, that is
actually unavailable.
> Markus, could you fix it, please (or give me the new address)? Thanks,
Replying to [comment:9 mloskot]:
> Marco/Markus,
> Also, please add ''spearfish'' name to the South Dakota dataset listed
in the installation wizard.
Yes,
already done in the current under-development installer: South Dakota will
be replaced with Spearfish County.
Replying to [comment:10 neteler]:
> Fixed:
> -rw-rw-r-- 1 neteler grass 141956914 May 18 12:34
nc_spm_08_2008_may18.tar.gz
> lrwxrwxrwx 1 neteler users 27 Jun 18 03:13
nc_spm_07_2007_dec20.tar.gz -> nc_spm_08_2008_may18.tar.gz
> lrwxrwxrwx 1 neteler users 27 Jun 18 03:14 nc_spm_latest.tar.gz
> Please use from now on "nc_spm_latest.tar.gz" as reference.
> Markus
