[GRASS-dev] [GRASS GIS] #1890: wingrass: lauch grass terminal fails
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: Startup | Version: svn-releasebranch64
Keywords: wingrass | Platform: MSWindows 7
      Cpu: x86-64 |
when starting grass on a fairly fresh Windows7 install, if you try to
launch the cmd.exe version of the grass terminal from the start menu
("GRASS $ver Command Line) you see a dos box flash up then disappear. If
you try it from an already-running cmd.exe window you see the error at the
DOS prompt:
The system cannot find the batch label specified -aftertextcheck
from then on the %PATH% is updated and many %GRASS_*% enviro variables
exist, but grass hasn't really started up and grass modules will not run.
this is a regression from grass 6.4.2, I suppose some goto: related
tragedy in the .bat file.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1890&gt;
#1890: wingrass: launch grass terminal fails
      Cpu: x86-64 |
Ticket URL: <https://trac.osgeo.org/grass/ticket/1890#comment:1&gt;
      Type: defect | Status: closed
Resolution: duplicate | Keywords: wingrass
  Platform: MSWindows 7 | Cpu: x86-64
Changes (by msieczka):
  * status: new => closed
  * resolution: => duplicate
Comment:
This is a duplicate of #1803, where I identified the root cause:
''The problem is in the etc\Init.bat where the "aftertextcheck" label is
used - looks like Windows expects "\r\n" at the end of the label name
rather than "\n".''
Closing this ticket and promoting #1803 to blocker.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1890#comment:2&gt;
