[GRASS-dev] [GRASS GIS] #1896: d.graph in console tries to add mapset
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
I just tried to use d.graph to display a legend made with
d.thematic.chart.
Here is the command: d.graph input=/Users/cmbarton/chartlegend
Here is the error:
Command 'd.graph
input=/Users/cmbarton/chartlegend@spatialtech2012' failed
Details: Graph file
</Users/cmbarton/chartlegend@spatialtech2012> not found
The console parsing algorithm is trying to add the mapset name to the text
file with d.graph commands. This is in 7.0. It may also be a problem in
other versions.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1896&gt;
      Cpu: Unspecified |
Comment(by annakrat):
Should be fixed (r55180). In grass 6.4, it is possible to display it only
as a command layer which works.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1896#comment:1&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
You are right. It works as a command layer in 6.4. The results are really
ugly, but that is not a fault of the gui.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1896#comment:2&gt;
      Cpu: Unspecified |
This works now in GRASS 7. Thanks!
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1896#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: Unspecified | Cpu: Unspecified
Changes (by cmbarton):
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1896#comment:4&gt;
