[GRASS-dev] [GRASS GIS] #1897: grass7 wxgui query: allow copying individual elements from query results
Reporter: mlennert | Owner: grass-dev@…
Component: wxGUI | Version: svn-trunk
Keywords: query | Platform: Unspecified
      Cpu: Unspecified |
In the current implementation of map querying in the grass7 wxgui, when
you click on the display a dedicated window ("Query results") opens with
the r/v.what results. One can copy the complete window contents to the
clipboard, but not individual elements.
This makes working with these results a bit tedious as if you need a
specific element you have to copy the entire contents of the window to a
text editor to then be able to copy just what you need.
It would be much more practical IMHO to be able to directly select and
copy individual elements.
Linked to that one might also question the need of the dedicated display
window. Why not simply continue to use the console output ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1897&gt;
      Cpu: Unspecified |
Comment(by annakrat):
Replying to [ticket:1897 mlennert]:
This is a limitation of wxPython. There are a few possibilities what to
do:
  * on right click show context menu with 'copy selected value'
  * add checkbox 'show query results also in command console'
  * let the user choose in preferences if to use the dialog or not (use
command console)
The dialog has some advantages:
  * dialog is more natural for new and not advanced users
  * the results are better organized, for example the output of raster
querying for more maps is a mess (but I understand that this argument is
more about the formatting than using dialog)
  * dialog uses tree structure, so you can hide some results
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1897#comment:1&gt;
      Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:1 annakrat]:
when you click on the display a dedicated window ("Query results") opens
with the r/v.what results. One can copy the complete window contents to
the clipboard, but not individual elements.
do:
Does this allow to select several lines of output and copy those, or would
this imply copying each element separately ? If the former, then I think
this would be a nice solution.
command console)
I think this will lead to more confusion. Let's stick to one place.
display window. Why not simply continue to use the console output ?
I can see the idea (although I'm not sure that this is true for everyone),
but at the same time there are some that criticize the window inflation in
GRASS. Having one place (command console) for output reduces that
inflation and IMO makes usage more consistent.
I do think that this can be solved by better formatting.
I agree that this is a nice feature, but not indispensable.
In summary, I won't make a religion out of the choice of dedicated window
vs console, but I do think that the query results have to be "copyable".
Also to echo an earlier debate [1], I still think that having the option
to access editable attributes without having to activate map feature
editing would be a plus.
Moritz
[http://lists.osgeo.org/pipermail/grass-dev/2013-February/062148.html 1]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1897#comment:2&gt;
Keywords: query, querying | Platform: Unspecified
      Cpu: Unspecified |
Changes (by wenzeslaus):
  * keywords: query => query, querying
Comment:
Moritz, can you please review your requests according to current status in
trunk (e.g. r59071)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1897#comment:3&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords: query, querying
  Platform: Unspecified | Cpu: Unspecified
Changes (by mlennert):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:3 wenzeslaus]:
in trunk (e.g. r59071)?
Yes, at this stage I can do all that I want. It would have been nicer to
be able to just select and copy arbitrary parts of the output in the
dedicated window, instead of having to go through command console just for
that, but I can live with it.
Editable attributes is still a wish, but that should be a separate ticket.
Closing the ticket as fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1897#comment:4&gt;
Replying to [comment:4 mlennert]:
status in trunk (e.g. r59071)?
Just to make sure, have you tried copying by right click and selecting
what you want to copy from the context menu?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1897#comment:5&gt;
Replying to [comment:5 annakrat]:
to be able to just select and copy arbitrary parts of the output in the
Yes, and it works fine, thank you. In the above, the word 'arbitrary' was
important, meaning that I can copy any part of the total output (i.e. any
number of lines). As I can do it via redirection to the command console it
is fine.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1897#comment:6&gt;
