[GRASS-dev] [GRASS GIS] #1901: v.mkgrid near ", ": syntax error, no batch insert
#1901: v.mkgrid near ",": syntax error, no batch insert
Reporter: pertusus | Owner: grass-dev@…
     Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: | Platform: Linux
      Cpu: Unspecified |
A v.mkgrid leads to:
v.mkgrid map=grid_map_v grid=$rows,$cols
DBMI-SQLite driver error:
Error in sqlite3_prepare():
ERREUR :Unable to insert new record: insert into grid_map_v values ( 1, 1,
         1 ), ( 2, 1, 2 ), ( 3, 1, 3 ), ( 4, 1, 4 ), ( 5, 1, 5 ), ( 6, 1, 6
         ), ( 7, 1, 7 ), ( 8, 1, 8 ), ( 9, 1, 9 ), ( 10, 1, 10 ), ( 11, 1,
         11 ), ( 12, 1, 12 ), ( 13, 1, 13 ), ( 14, 1, 14 ), ( 15, 1, 15 ),
         16, 1, 16 ), ( 17, 1, 17 ), ( 18, 1, 18 ), ( 19, 1, 19 ), ( 20, 1,
         20 )
Trying manually:
db.execute sql=" insert into grid_map_v values ( 3, 1, 3 ), ( 4, 1, 4 )"
And trying in sqlite directly:
sqlite> create table grid_map_v ( cat INTEGER, row INTEGER, col INTEGER );
sqlite> insert into grid_map_v values ( 1, 1, 1), ( 2, 1, 2 );
Error: near ",": syntax error
sqlite> insert into grid_map_v values ( 1, 1, 1);
The batch insertion is shown in http://www.sqlite.org/lang_insert.html,
however I am not sure that it is standard sql. I don't know where to find
the standard, but on http://troels.arvin.dk/db/rdbms/#insert-multiple it
is described as optional.
The commit that introduced that issue is the last commit
r53891 | marisn | 2012-11-18 13:40:34 +0100 (dim. 18 nov. 2012) | 1 ligne
Make some errors more fatal; Write attribute data in batches per 20 to
speed up module 16x times
I will set BATCH_SIZE 1 for now but I am not sure it is the correct fix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1901&gt;
Keywords: v.mkgrid | Platform: Linux
      Cpu: Unspecified |
Changes (by marisn):
  * keywords: => v.mkgrid
Comment:
Multirow inserts are valid since SQL-92. I would still stay on side, that
this feature should be left as is as speed difference on large grids is
enormous but non-SQL-92 RDBMSes are disappearing.
According to Wikipedia: "This feature is supported by DB2, SQL Server
(since version 10.0 - i.e. 2008), PostgreSQL (since version 8.2), MySQL,
sqlite (since version 3.7.11) and H2". Solution - upgrade sqlite.
Second option - add extra logic to switch to slingle row inserts if
multirow fails. Still I have no time now to implement it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1901#comment:1&gt;
      Cpu: Unspecified |
Comment(by pertusus):
I use a centos 6, by no mean an old platform, but sqlite here is
sqlite-3.6.20, thus I think that relying, in the default case on that
feature is not a good idea. Updating system sqlite is a very bad idea,
using a non system sqlite for grass is very impractical (and prevents
updating packages).
Also, I read the standard
http://www.contrib.andrew.cmu.edu/~shadow/sql/sql1992.txt, and it seems to
me that the "63)Subclause 13.8" says that for "Entry SQL" there should
only be one value, which explains why this feature is that badly
implemented in SQL implementations. According to the sqlite news, sqlite
3.7.11 dates from 2012-March-20!
Ticket URL: <http://trac.osgeo.org/grass/ticket/1901#comment:2&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:2 pertusus]:
updating packages).
I have fixed r53891 in r55271. No more batch insert, but the module is now
about 50x faster than the batch insert, using old-fashioned begin/commit
transaction.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1901#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.mkgrid
  Platform: Linux | Cpu: Unspecified
Changes (by pertusus):
  * status: new => closed
  * resolution: => fixed
Comment:
Thanks, it works now, and it is indeed quite fast.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1901#comment:4&gt;
