GDAL
June 20, 2008, 2:14pm
1
#192: ps.map: geogrid RGB color and ellipsoid
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Priority: trivial | Milestone: 6.4.0
Component: default | Version: svn-trunk
Keywords: ps.map geogrid ellipsoid RGB |
ps.map's geogrid command only accepts named colors currently. it should be
updated to accept R:G:B as well.
Also it is unclear to me which ellipsoid geogrid uses. I suspect it is the
current one, which is fine, but it would be nice to add an option to use
WGS84's instead, like "d.grid -w".
thanks
Hamish
ps- can we have "ps.map" added to the trac Component drop down list?
Ticket URL: <http://trac.osgeo.org/grass/ticket/192> ;
GRASS GIS <http://grass.osgeo.org >
done.
GDAL
November 29, 2008, 4:54am
3
Component: ps.map | Version: svn-trunk
Resolution: | Keywords: ps.map geogrid ellipsoid RGB
Platform: Unspecified | Cpu: Unspecified
Changes (by hamish):
* platform: => Unspecified
* component: default => ps.map
* cpu: => Unspecified
Ticket URL: <http://trac.osgeo.org/grass/ticket/192#comment:1> ;
GDAL
May 8, 2009, 10:23am
4
Priority: trivial | Milestone: 6.5.0
* milestone: 6.4.0 => 6.5.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/192#comment:2> ;
GDAL
March 25, 2011, 6:40am
5
Reporter: hamish | Owner: grass-dev@…
Component: Ps.map | Version: svn-trunk
Keywords: ps.map geogrid ellipsoid RGB | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
Replying to [ticket:192 hamish]:
> Hi,
be updated to accept R:G:B as well.
the current one, which is fine, but it would be nice to add an option to
use WGS84's instead, like "d.grid -w".
> thanks
> Hamish
R:G:B is not supported by other commands, too. Mapinfo (color, background,
border) and vlegend (border) are supported by the new GUI, so they should
be fixed first.
Other commands which accept only named colors are: grid, geogrid, header,
outline, setcolor. GUI does't support them yet, so these can wait.
Thanks
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/192#comment:3> ;
GDAL
March 27, 2011, 1:11am
6
Reporter: hamish | Owner: hamish
Type: enhancement | Status: assigned
Priority: normal | Milestone: 6.5.0
Cpu: Unspecified |
* cc: grass-dev@… (added)
* owner: grass-dev@… => hamish
* status: new => assigned
* priority: trivial => normal
Comment:
Anna:
background, border)
> and vlegend (border) are supported by the new GUI, so they should be
fixed first.
ok, will-do.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/192#comment:4> ;
GDAL
March 27, 2011, 2:31am
7
Cpu: Unspecified |
Comment(by hamish):
RGB support added to mapinfo in 6.5&7 in r45774,5.
RGB support added to vlegend in 6.5&7 in r45776,7.
example showing mapinfo background working just until
the point where the mapinfo box does not overlap the
main map box: (change y=6.45 to 6.50 to see it fall off the edge)
#spearfish
g.region -d
ps.map out=test.ps << EOF
raster elevation.dem
mapinfo
where 2 6.45
color 200:10:200
background 150:200:200
border 250:220:50
end
end
EOF
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/192#comment:5> ;
GDAL
March 27, 2011, 8:31am
8
Cpu: Unspecified |
Replying to [comment:5 hamish]:
Thanks, I made the correction you suggested (use named color in the
instruction file if possible).
I know about this, I suppose this behaviour is a bug. I forgot to mention
it.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/192#comment:6> ;
GDAL
August 17, 2011, 10:42am
9
Cpu: Unspecified |
Comment(by hamish):
full support fro RGB colors added to the grid and geogrid instructions in
devbr6 and trunk in r47689,90.
todo: PS.outline_color and hdr.color.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/192#comment:7> ;
GDAL
August 17, 2011, 1:43pm
10
Cpu: Unspecified |
Comment(by hamish):
header, outline, and setcolor instructions now accept full RGB colors.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/192#comment:8> ;
GDAL
September 9, 2011, 12:04am
11
Priority: normal | Milestone: 6.4.2
Cpu: Unspecified |
* milestone: 6.5.0 => 6.4.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/192#comment:9> ;
GDAL
January 14, 2012, 11:19pm
12
Priority: normal | Milestone: 6.4.3
Cpu: Unspecified |
* milestone: 6.4.2 => 6.4.3
Comment:
Replying to [comment:8 hamish]:
todo: backport to 6.4
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/192#comment:10> ;
GDAL
August 21, 2012, 5:11pm
13
Cpu: Unspecified |
Comment(by neteler):
Hamish, please backport to G6.4.
Ticket URL: <http://trac.osgeo.org/grass/ticket/192#comment:11> ;
GDAL
February 22, 2013, 11:48am
14
Keywords: ps.map, geogrid, ellipsoid, RGB | Platform: Unspecified
Cpu: Unspecified |
* keywords: ps.map geogrid ellipsoid RGB => ps.map, geogrid, ellipsoid,
RGB
Comment:
backported RGB support for a number of instructions and various small
bugfixes in r55176.
please test(!).
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/192#comment:12> ;
GDAL
April 24, 2013, 1:15pm
15
Cpu: Unspecified |
Comment(by hamish):
full RGB support for 'setcolor' backported to relbr64 in r55981. the rest
which were already backported tested ok.
still todo before closing this ticket:
the
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/192#comment:13> ;
