[GRASS-dev] [GRASS GIS] #1928: after v.transform v.to.db gives incorrect length
Reporter: pertusus | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: svn-releasebranch64
Keywords: | Platform: Linux
      Cpu: Unspecified |
I import a dxf without georeferenced information, then scale it with
v.transform. After that the line length obtained through v.to.db is wrong.
If I export the line with v.out.ascii and reimport it, the length is
correct.
A tarball to reproduce is attached.
tar xzvf bug_grass.tar.gz
cd bug_grass
./reproduce.sh
The script will show the lengths that are much lower than the correct
length (should be like 3300 for the first line, for instance).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1928&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [ticket:1928 pertusus]:
The bug in v.to.db is that it does not use geodesic distance calculations
in latitude-longitude projections. Fixed in trunk r55729.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1928#comment:1&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:1 mmetz]:
calculations in latitude-longitude projections.
Applies to 3D vectors only.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1928#comment:2&gt;
      Cpu: Unspecified |
Comment(by pertusus):
It works now. It also affects 6.4.3svn. Do you want that I apply the
changeset patch and test there?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1928#comment:3&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:3 pertusus]:
Tested and backported with r55746-7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1928#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: Linux | Cpu: Unspecified
Changes (by pertusus):
  * status: new => closed
  * resolution: => fixed
Comment:
Tested too in 6.4.3 svn branch, it works, closing now, thanks.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1928#comment:5&gt;
