[GRASS-dev] [GRASS GIS] #1936: wxGUI command console: "Protocol" isn't really the right word & cleanup
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: unspecified
Keywords: command console | Platform: Unspecified
      Cpu: Unspecified |
in the wxGUI command console tab there's a "Protocol" button.
I don't think the word really fits, or at least it's an awkward use of it.
Perhaps "Journal", "Command Log", or "History" would be better? "script"
might also fit, but I'd worry it would get confused with running a script.
(my 2c vote would go to "Journal", and if we're going to change it we
should try before the release)
thanks,
Hamish
ps- also in the command console tab, "Click here to show search module
engine >>" .. shouldn't that be on the Search module tab instead of taking
valuable screen real estate away from the output canvas?
pps- still in the command console tab: there's an empty bar above the
Clear/Save button row. When it's not being used for % done, could it do
double duty and go below the buttons with "Manually enter commands below:"
or some text? To a new user, at the start that tab just has two big white
boxes, it's not clear what either of them are and that it is possible to
type into the lower pane and have it do something.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1936&gt;
      Cpu: Unspecified |
Comment(by hamish):
any comments?
objections to changing it to "Journal" or "Command log" or "Command
history"?
preferences?
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1936#comment:1&gt;
      Cpu: Unspecified |
Comment(by hamish):
patch against devbr6 attached for your consideration.
also, I'd suggest on line ~780 goutput.py to change opening the file as
write-new to write-append, so that your old command log doesn't get
overwritten:
          try:
             output = open(self.cmdFileJournal, "w")
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1936#comment:2&gt;
      Cpu: Unspecified |
Comment(by wenzeslaus):
"Journal" is for non-native speaker the same or, in my case, even worse
than "Protocol".
What about "Record" or "Log"? E.g., in gmail chat there is "Go off the
record". Moreover, the current behavior is that after choosing the file
name, the button is toggled and the GUI is recording commands.
Also note that wxGUI code in goutput was changed in trunk and any patches
cannot be easily back- or forward-ported. In this case, I would suggest to
change code and user visible strings only in trunk and in
releasebranch_6_4 I would change only the strings.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1936#comment:3&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:3 wenzeslaus]:
than "Protocol".
I would tend to agree with Vaclav, "journal" in this meaning is quite
cryptic for non-native speaker.
Probably "Record", no strong preferences.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1936#comment:4&gt;
      Cpu: Unspecified |
Comment(by hamish):
I'm curious about this, can you say what "journal" translates to for you?
(considering that it will not always appear as translated)
From my personal, but native speaker, POV "Journal" is the best
of the lot. You'll see it also used for "journaling file system",
it's traditionally a personal book you keep notes in, and in
finance as "journaled the expense into the ledger".
It seems to me something like "The Wall Street Journal" is a bit of
a colloquialism or play on financial words.
"Log" could work, but I'd expand it to "command log" or "log history"
or something like that. I work on ships a quite a bit and the
ship's log, where all maintenance, events, and details of the current
situation at shift changes are noted, is still heavily used.
The difference between journal and log might be that log is a bit
more of a formal record of events.
"Log file" might be ok too, but it could suggest that the entire session
would be logged, including output. Everyone would know exactly what it
meant though, so maybe a winner there.
The great "ah-ha" moment comes when the user realizes that they can
'chmod u+x' the file or rename it to ".bat", and they instantly have
a runable shell script for their workflow. Super-low barrier entry
to scripting/writing their first program. Typically that will want
some editing and cleanup first, so the "scratch pad" idea of a journal
appeals to me more than the frozen history/archive meaning that a
log instills.
iPython has gone with "notebook", but I think that's too much of an
interactive meaning for what the button does.
As for "Record", that sounds to me more like a screencast sort of
thing, or a button for keeping audio notes. Or at least someone
somewhere will misinterprept it as that.
It's all just semantics of course with no right answer, but the
choice of words can make all the difference in providing subtle clues
to the user about the meaning of the tool.
The "Protocol" meaning doesn't help the programmer understand much
at all what it is talking about, they are more likely to think it
has to do with some communication API, so I'd change it everywhere.
It's only 10-20 lines.
Martin:
> quite cryptic for non-native speaker.
perhaps, but it also seems to me to be the most correct.
what other meaning/idea do you get from it?
shrug,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1936#comment:5&gt;
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:5 hamish]:
you?
It translates to "academic paper" or newspaper (remember that non-native
speakers do not well the intended meaning nor will they take a dictionary
to look it up.
> of the lot.
I am pretty much -1 on using the "journal" here. Let's not add more
confusion.
I agree that "Protocol" is confusing, too. So, for example "Log file" is
fairly clear.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1936#comment:6&gt;
      Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:6 neteler]:
ok, fair enough.
confusion.
is
> fairly clear.
sure, let's use that.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1936#comment:7&gt;
      Cpu: Unspecified |
Comment(by hamish):
label string rename now applied in all branches. variable renaming not yet
done.
Also I changed it from overwrite existing file of the same name to append
to file.
Hamish
(argh, more trac logging itself out..)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1936#comment:8&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: command console
  Platform: Unspecified | Cpu: Unspecified
Changes (by wenzeslaus):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:8 hamish]:
yet done.
Variable rename is not so important and might be done as a part of some
larger refactoring.
Closing as fixed.
append to file.
This is surely very useful change, although maybe not expected by all, but
it's the safer behavior anyway.
Change done in r56094.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1936#comment:9&gt;
