[GRASS-dev] [GRASS GIS] #1940: wingrass - nsis - script in release mode: !define SVN_REVISION "@GRASS_VERSION_SVN@" not set
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Packaging | Version: 6.4.3 RCs
Keywords: nsis | Platform: MSWindows 7
      Cpu: x86-64 |
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows
/GRASS-Installer.nsi.tmpl#L19
19 ;Select if you are building a "Development Version" (Devel) or a
"Release Version" (Release) of the GRASS Installer
20
21 !define INSTALLER_TYPE "Devel"
/GRASS-Installer.nsi.tmpl#L31
31 ;Version variables
32
33 !define SVN_REVISION "@GRASS_VERSION_SVN@"
in release mode @GRASS_VERSION_SVN@ isn't set:
!define SVN_REVISION "" <=
!define BINARY_REVISION "1"
!define VERSION_NUMBER "6.4.3RC3"
!define GRASS_BASE "GRASS GIS 6.4.3RC3"
so
/GRASS-Installer.nsi.tmpl#L251
251 !define /math VERSION ${SVN_REVISION} + ${BINARY_REVISION}
doesn't work and nsis stopps with an error
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [ticket:1940 hellik]:
source get by a svn checkout
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:1&gt;
      Cpu: x86-64 |
Comment(by martinl):
> 20
The installer type should be not related to this ticket. At least I didn't
encountered any problem when building osgeo4w package source:grass-
addons/tools/wingrass-packager/grass_svn_info.sh#L34
> 32
replacement should be done automatically
(source:grass/branches/releasebranch_6_4/mswindows/Makefile#L22) when SVN
rev number is defined in
source:grass/branches/releasebranch_6_4/include/Make/Grass.make.in#L75. Do
you have `svnversion` in the path (when running `configure`)?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:2&gt;
      Cpu: x86-64 |
Changes (by martinl):
* cc: martinl (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:3&gt;
      Cpu: x86-64 |
Replying to [comment:2 martinl]:
source code downloaded from SVN? If you use tarball, it will fail (missing
svn number).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:4&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:4 martinl]:
(missing svn number).
see
#1940#comment:1
source was from a svn check out
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:5&gt;
      Cpu: x86-64 |
Comment(by hellik):
> Do you have `svnversion` in the path (when running `configure`)?
from the msys-cmdline
myricaria@MYRICARIA-HP ~
$ svnversion --version
svnversion, version 1.7.0 (r1176462)
    compiled Oct 10 2011, 22:03:27
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:6&gt;
      Cpu: x86-64 |
Comment(by hamish):
just to note in the release tarball there are no .svn/ dirs present, so
svnversion (if installed) should just return "exported" to stdout.
I'm not sure what happens with 'svn export' of a branch, I assume the
same, but hellik reports using 'svn checkout', which should have .svn/
dirs, so something else is going on.
If there are things which need to be changed just before release, then
changed back just after, automatically-detecting is best but if that is
not possible please document what needs to be done in
src:doc/howto_release.txt.
fwiw,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1940#comment:7&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:7 hamish]:
> Hi,
Author: neteler
Date: 2013-04-20 08:29:47 -0700 (Sat, 20 Apr 2013)
New Revision: 55934
myricaria@MYRICARIA-HP /osgeo4w/usr/src/grass643RC3
$ svnversion
55936
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:8&gt;
      Cpu: x86-64 |
Replying to [comment:6 hellik]:
When you launch `configure` or better `package.sh` you should get (see
`package.log`)
checking for svnversion... /c/Subversion/svnversion
`include/Make/Grass` should contain
GRASS_VERSION_SVN = XXXXXX
In other words, try to check if `svnversion` is in the path when running
`package.sh`. (?)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:9&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:9 martinl]:
`package.log`)
`package.sh`. (?)
from package log
checking for svnversion... no
from osgeo4w-msys from where I start package.sh
$ svnversion --help
usage: svnversion [OPTIONS] [WC_PATH [TRAIL_URL]]
from osgeo4w-msys from where I start package.sh osgeo4w-msys
$ echo $PATH
/c/Program Files/TortoiseSVN/bin:
and in /c/Program Files/TortoiseSVN/bin: there is svnversion
so it's seems it's in $PATH, but not found by configure
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:10&gt;
Keywords: nsis, wingrass | Platform: MSWindows 7
      Cpu: x86-64 |
Changes (by hamish):
  * keywords: nsis => nsis, wingrass
Comment:
Replying to [comment:10 hellik]:
from the subject of this bug it seems the issue has to do with building an
official versioned release, not with a random svn snapshot build?
In that case the svn rev and thus svnversion are mostly irrelevant;
".svn/" metadata is not in the final tarball, and if a historian is
curious what svn rev the version refers to they can always look it up in
the tag's log. For versioned releases it already has an official version
number, so we know exactly which version of the codebase the user is
talking about- the point of including svn revs is to provide that info for
non-official-versioned checkouts.
of course the packaging script should handle all the variable setting (or
leaving blank) cleanly for you once you change the "Devel" keyword to
"Release"...
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1940#comment:11&gt;
      Cpu: x86-64 |
Comment(by hamish):
I'm not sure what the status of this one is, but it seems that building
the RC4 wingrass package will be a good opportunity to field test what
happens to the build when there is no .svn/ metadata in the tarball GRASS
is built from.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1940#comment:12&gt;
      Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:11 hamish]:
an official versioned release, not with a random svn snapshot build?
the tag's log.
see
${VERSION} is used in the nsis-script/wingrass-installer to check if the
installer is newer/older than the already installed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:13&gt;
Reporter: hellik | Owner: martinl
      Cpu: x86-64 |
* cc: martinl (removed)
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:14&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: nsis, wingrass
  Platform: MSWindows 7 | Cpu: x86-64
Changes (by hellik):
  * status: new => closed
  * resolution: => fixed
Comment:
fixed by r59313
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:15&gt;
