[GRASS-dev] [GRASS GIS] #1946: wingrass: demolocation includes .svn/ cruft
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Packaging | Version: svn-develbranch6
Keywords: wingrass | Platform: MSWindows XP
      Cpu: x86-32 |
the nightly build wingrass installers ship '.svn/' files for the
demolocation.
perhaps somewhere needs to do 'svn export' not 'svn checkout'?
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946&gt;
      Cpu: x86-32 |
Comment(by neteler):
Replying to [ticket:1946 hamish]:
demolocation.
To better understand: is it a problem?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:1&gt;
      Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:1 neteler]:
demolocation.
It does not cause breakage, but it should be removed.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:2&gt;
Priority: trivial | Milestone: 6.4.3
      Cpu: x86-32 |
Changes (by martinl):
  * priority: normal => trivial
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:3&gt;
      Cpu: x86-32 |
Comment(by hamish):
please don't ignore it. it's a 2 minute job and these things make us look
unprofessional.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:4&gt;
      Cpu: x86-32 |
Comment(by martinl):
Replying to [comment:4 hamish]:
look unprofessional.
huh, "trivial" means ignoring? if it's a 2 minute job, feel free to fix
it. Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:5&gt;
      Cpu: x86-32 |
Comment(by hamish):
.. it seemed to be going that way. Yes, I had a look at fixing it myself
before filing the ticket, but couldn't see where in src:mswindows/ and
addons:tools/wingrass-packager/ it was done. Any hints?
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:6&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:6 hamish]:
myself before filing the ticket, but couldn't see where in src:mswindows/
and addons:tools/wingrass-packager/ it was done. Any hints?
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/mswindows
/GRASS-Installer.nsi.tmpl#L13
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:7&gt;
      Cpu: x86-32 |
Comment(by hamish):
so, IIUC, the packager does a 'svn up' on their machine into a local
C:\osgeo4w dir, then the packaging script recursively copies from within
that checked out source tree?
http://trac.osgeo.org/grass/wiki/CompileOnWindows#CreatetheWinGRASSInstaller
Line 586 of GRASS-Installer.nsi.tmpl has:
File /r ${DEMOLOCATION_PATH}\*.*
how to restrict that, or afterwards recursively rm the 6 .svn/ dirs within
it?
or just forget anything fancy and remove them by hand after the copy:
RMDir /r "$GIS_DATABASE\demolocation/.svn"
RMDir /r "$GIS_DATABASE\demolocation/PERMANENT/.svn"
RMDir /r "$GIS_DATABASE\demolocation/PERMANENT/vector/.svn"
RMDir /r "$GIS_DATABASE\demolocation/PERMANENT/vector/mysites/.svn"
RMDir /r "$GIS_DATABASE\demolocation/PERMANENT/vector/point/.svn"
RMDir /r "$GIS_DATABASE\demolocation/PERMANENT/dbf/.svn"
http://nsis.sourceforge.net/Delete_files_and_subdirectories
(I think that recursive remove is also needed for the extracted ms VC++
dll dir in Temp/, right now it gets left behind after install)
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:8&gt;
      Cpu: x86-32 |
Replying to [comment:8 hamish]:
see
source:grass-addons/tools/wingrass-packager/grass_compile.sh#L14
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:9&gt;
      Cpu: x86-32 |
Comment(by hellik):
/GRASS-Installer.nsi.tmpl#L1000
Delete "$TEMP\$ARCHIVE_NAME"
Delete "$TEMP\$ORIGINAL_UNTAR_FOLDER"
the downloaded files and folders should be deleted.
if e.g. vcredist_2005_x86.exe creates another folder with extracted files,
shouldn't be this cleaning the os?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:10&gt;
      Cpu: x86-32 |
Comment(by hamish):
left over in ...\Local Settings\Temp\ are a install_msruntime dir from
osgeo4w, with bin/ and etc/ within it, and an empty "Microsoft Visual C++
Runtime 2010 x86 Redistributible Setup_10.0.30319" dir, and matching 2010
.html and .txt log files.
wrt the 'install_msruntime' dir, does "Delete" work for folders?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1946#comment:11&gt;
      Cpu: x86-32 |
Comment(by glynn):
demolocation.
I think that this isn't restricted to Windows; the "builddemolocation"
target in the top-level Makefile simply copies the demolocation directory
to dist.<arch> (using "tar c ... | tar x ...").
In 7.x, the demolocation directory has a Makefile which explicitly creates
target directories and copies files with $(INSTALL_DATA).
Also: recent versions of the subversion client use a single .svn directory
in the root of the working directory, rather than having a separate .svn
directory in each subdirectory, so updating the subversion client would
make this particular issue disappear.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1946#comment:12&gt;
      Cpu: x86-32 |
Comment(by hamish):
attempt to remove the unpacked 'install_msruntime' dir in devbr6 r56001.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1946#comment:13&gt;
      Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:12 glynn]:
demolocation.
directory
that is correct, it's in all 'make install' for svn builds.
> creates target directories and copies files with $(INSTALL_DATA).
since there's no `Other.make` in grass6 I'd just go with the cheap & dirty
approach-of-least-change:
Index: Makefile
--- Makefile (revision 55903)
+++ Makefile (working copy)
@@ -389,6 +389,13 @@
  builddemolocation:
         test -d ${ARCH_DISTDIR} || ${MAKE_DIR_CMD} ${ARCH_DISTDIR}
         -tar cBf - demolocation | (cd ${ARCH_DISTDIR}/ ; tar xBfo - )
2>/dev/null
+ -(cd ${ARCH_DISTDIR}/demolocation ; \
+ rm -rf ".svn" ; \
+ rm -rf "PERMANENT/.svn" ; \
+ rm -rf "PERMANENT/vector/.svn" ; \
+ rm -rf "PERMANENT/vector/mysites/.svn" ; \
+ rm -rf "PERMANENT/vector/point/.svn" ; \
+ rm -rf "PERMANENT/dbf/.svn" )
         @ echo "GISDBASE: ${RUN_GISBASE}" > ${RUN_GISRC}
         @ echo "LOCATION_NAME: demolocation" >> ${RUN_GISRC}
         @ echo "MAPSET: PERMANENT" >> ${RUN_GISRC}
I notice that the last part creates a file called demolocation/.grassrc65,
when it should perhaps be .grassrc6? That's named by Platform.make.in:
RUN_GISRC =
${ARCH_DISTDIR}/demolocation/.grassrc${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}
(RUN_GISRC is used by e.g. Man.make at build time, with the GISRC=
override set to the same variable, so it doesn't matter much what it's
called)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1946#comment:14&gt;
      Cpu: x86-32 |
Comment(by hamish):
second call for comments on the cheap & dirty patch in comment:14.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1946#comment:15&gt;
      Cpu: x86-32 |
Comment(by hamish):
patch committed in devbr6 and relbr64, but only affects 'make install',
which the nsis installer doesn't use.
another attempt at cleaning it up wingrass committed in devbr6 r56107.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1946#comment:16&gt;
      Cpu: x86-32 |
Comment(by hamish):
wingrass7 was also copying over the .svn/ files (doesn't use 'make
install', just copies from source dir), devbr6 fix for that merged to
trunk in r56108.
I also notice in a wingrass7 install that a Makefile and grassrc.tmpl file
have made it into $GISBASE/demolocation.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1946#comment:17&gt;
      Cpu: x86-32 |
Replying to [comment:5 martinl]:
it. Martin
as you can see such "2 minutes jobs" are usually taking more then "2
minutes", currently stand-alone installer for G65 and G70 are broken
SetOutPath: "$GIS_DATABASE\demolocation"
File: Returning to: "."
File: "$DEMOLOCATION_PATH" -> no files found.
Usage: File [/nonfatal] [/a] ([/r] [/x filespec [...]] filespec [...] |
    /oname=outfile one_file_only)
Error in script ".\grass65\GRASS-Installer.nsi" on line 586 -- aborting
creation
  process
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:18&gt;
      Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:18 martinl]:
creation
   process
try r56130,1. Probably nothing to do with .svn/ additions, just me not
understanding the nsis scripting language very well in a side-edit.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:19&gt;
