[GRASS-dev] [GRASS GIS] #1951: Postgres database login problems in db.databases
Reporter: davidinosauro | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
      Cpu: x86-64 |
Just installed grass7 (freshly compiled) and ran into this problem: with
some modules, grass seems unable to login into the Postgres db, as it
tries to connect as a different user:
`v.db.reconnect.all` gives me a few of theese errors:
DBMI-PostgreSQL driver error:
Connection failed.
FATAL: role "davide" does not exist
ERROR: Unable to create database <host=localhost,dbname=test,port=5432> by
     driver <pg>
Where "davide" is actually my username, while I previously ran
`db.login user=postgres password=***`
in fact, most modules correctly connect to db (I can run `v.in.ogr` and
import a shapefile, which will properly create a table on db)
However, the following modules (at least) fail with that error:
   * `v.db.reconnect.all -cd`
   * `db.databases` (which I found was called by v.db.reconnect.all)
   * `grass.pygrass.vector.VectorTopo.open` called from the python shell
I did't dig deep into the problem, but I guess the wrong username could be
the result of calling the db client without explicitly specifying the
username.
Davide Kirchner
Ticket URL: <http://trac.osgeo.org/grass/ticket/1951&gt;
      Cpu: x86-64 |
Comment(by davidinosauro):
Update: Hoping the thing was easy enough for me to fix it, I browsed a
while into the code, but I realized it is not as easy as it seems.
I realized the problem in pygrass may be distinct from the one in
db.databases, because pygrass directly calls psycopg2.connect (at
source:/grass/trunk/lib/python/pygrass/vector/table.py#L641).
But even if I found the place where the fix would probably go, I couldn't
work out a way of getting the db credentials without explicitly reading
from `~/.grass7/dblogin` or `~/.pgpass`, wich does not seem a good idea in
terms of avoding code replication (even if I could not find it, I bet
there is some c module which does exately this).
I forgot to explitely mention the steps to reproduce:
  - Set up a postgres with password authentication (just to be sure, with
no username equal to the unix user GRASS runs with, and with no
`~/.pgpass` entry)
  - `db.connect` and `db.login` to that postgres
  - create a vector map with attribute table on that postgres (I used
`v.in.ogr`)
  - from the python shell:
#!python
from grass.pygrass.vector import VectorTopo # guess would be the same with
Vector
v = VectorTopo('map_name')
v.open()
  - same error would be generated from `db.databases`
Ticket URL: <http://trac.osgeo.org/grass/ticket/1951#comment:1&gt;
Component: Database | Version: svn-trunk
Keywords: postgres, login | Platform: Linux
      Cpu: x86-64 |
Changes (by martinl):
  * keywords: => postgres, login
  * component: Default => Database
  * milestone: => 7.0.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/1951#comment:2&gt;
Keywords: postgres, login, db.databases | Platform: Linux
      Cpu: x86-64 |
Changes (by neteler):
  * keywords: postgres, login => postgres, login, db.databases
Ticket URL: <http://trac.osgeo.org/grass/ticket/1951#comment:3&gt;
Keywords: python, postgres, login, db.databases | Platform: Linux
      Cpu: x86-64 |
  * keywords: postgres, login, db.databases => python, postgres, login,
               db.databases
Ticket URL: <http://trac.osgeo.org/grass/ticket/1951#comment:4&gt;
      Cpu: x86-64 |
Comment(by neteler):
In order to get interactive password prompting back (removed in r32551),
could we use code from here for *only* db.login?
sprompt.c: http://doxygen.postgresql.org/sprompt_8c_source.html
  * simple_prompt
  * Generalized function especially intended for reading in usernames and
  * password interactively. Reads from /dev/tty or stdin/stderr.
  * prompt: The prompt to print
  * maxlen: How many characters to accept
  * echo: Set to false if you want to hide what is entered (for
passwords)
  * Returns a malloc()'ed string with the input (w/o trailing newline).
Rationale: It is "ugly" to send clear text passwords through command line.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1951#comment:5&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:5 neteler]:
Maybe. At a minimum, interactive prompting would need to be specifically
requested. If db.login is spawned from the GUI, trying to interact with
the user via stdin or /dev/tty isn't likely to be useful.
While the GUI can (and should) just close/redirect stdin prior to
executing commands, intercepting an explicit open("/dev/tty") is somewhat
harder (I'm not sure that the equivalent is even possible on Windows).
It might be better to have db.login spawn an external program for such
things, with the program specified by an environment variable and/or
command-line option. This would keep all of the platform-specific ugliness
out of db.login itself, and would also allow the use of different programs
in different environments (e.g. a dialog box for GUI environments).
Assuming that the password is being stored somewhere (presumably this is
required so that subsequent db.* or v.* commands can connect
automatically), it's essential that reasonable security precautions are
taken.
An external program could either transmit the password back to db.login,
or could persist as an agent (similar to ssh-agent) which would be
accessed by subsequent modules. In the latter case, the password need only
be stored in the agent's memory; however, this would necessitate the use
of sockets or similar IPC mechanisms.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1951#comment:6&gt;
