[GRASS-dev] [GRASS GIS] #1952: wingrass: please add tac and seq to extrabin
Reporter: hamish | Owner: grass-dev@…
Priority: normal | Milestone: 6.4.3
Component: Packaging | Version: svn-develbranch6
Keywords: wingrass | Platform: MSWindows XP
      Cpu: x86-32 |
tac.exe and seq.exe are no longer shipped with wingrass. (I'm not sure if
tac ever was)
I'm pretty sure `seq` used to be there (in msys/bin/?) but it seems to
have gone away.
if it's an easy thing to do, could we install these unix powertools to
msys/bin/ or extrabin/?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952&gt;
      Cpu: x86-32 |
Comment(by hamish):
more.exe is missing from the wingrass bash prompt too.
thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:1&gt;
      Cpu: x86-32 |
Comment(by neteler):
See also ticket #1275 (zip.exe)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:2&gt;
      Cpu: x86-32 |
Comment(by hamish):
* http://trac.osgeo.org/osgeo4w/wiki/pkg-msys
  * http://lists.osgeo.org/pipermail/grass-dev/2013-June/064214.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:3&gt;
      Cpu: x86-32 |
Comment(by hamish):
xml2.exe, too (for r.in.wms[.sh]).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:4&gt;
      Cpu: x86-32 |
Can a winGRASS user please check if these commands are now in the
installer?
  * bc
  * more
  * seq
  * tac
  * xml2
? Thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:5&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:5 neteler]:
installer?
> * bc
> * more
> * seq
> * tac
> * xml2
> ? Thanks.
* bc => available in C:\OSGeo4W\bin
* more => '''not''' available in C:\OSGeo4W\bin
* seq => '''not''' available in C:\OSGeo4W\bin
* tac => '''not''' available in C:\OSGeo4W\bin
* xml2 => '''not''' available in C:\OSGeo4W\bin
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:6&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:1 hamish]:
> thanks
windows operating systems ship their own more-version.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:7&gt;
      Cpu: x86-32 |
Comment(by hellik):
installer?
> * bc
> * more
> * seq
> * tac
> * xml2
> ? Thanks.
seq and tac-download available: http://sourceforge.net/projects/unxutils/
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:8&gt;
      Cpu: x86-32 |
Comment(by martinl):
Replying to [comment:8 hellik]:
I will put it do my TODO (update msys-grass package).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:9&gt;
      Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:9 martinl]:
thanks. any idea about xml2?
just a quick test with
System Info
GRASS Version: 6.4.4svn
GRASS SVN Revision: 58663
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.10.1
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
Import raster data -> WMS import -> Connect
with the second example from the manual with Land Cover
(http://grass.osgeo.org/grass64/manuals/r.in.wms.html)
error message
the xml2 parser is required, please install it first...
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:10&gt;
      Cpu: x86-32 |
Comment(by glynn):
Replying to [ticket:1952 hamish]:
if tac ever was)
tac and seq aren't specified by POSIX. Any scripts which use them should
be modified to work without them.
Not only is seq trivial to implement as a shell function, I can't find
anything which actually uses it.
The only user of tac appears to be v.in.mapgen, which provides its own
implementation (using awk) as a fallback.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:11&gt;
      Cpu: x86-32 |
Comment(by wenzeslaus):
Replying to [comment:11 glynn]:
if tac ever was)
I would expect that users wants to use them in their own scripts, or their
might be used in addons. The fact is that their are used in manual,
however each just once/twice:
dist.../docs/html $ egrep -Irn "tac " .
./m.cogo.html:169: m.cogo -l in=cogo.dat | tac | awk '
./m.cogo.html:172: END { printf("L %d\n", R) }' | tac | \
dist.../docs/html $ egrep -Irn "seq " .
./d.out.gpsdrive.html:139:for i in `seq 1 $panels_ew`;
./d.out.gpsdrive.html:142: for j in `seq 1 $iter`;
I would just ignore these two.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1952#comment:12&gt;
