[GRASS-dev] [GRASS GIS] #1959: wingrass wx carto composer: Image causes traceback
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: cartographic composer | Platform: MSWindows XP
      Cpu: x86-32 |
testing latest 6.5svn nightly wingrass build.
If you open the wxGUI cartographic composer and pick 'add map element'
then "Image" (better to call that 'map decorations'?; better to make menu
item "EPS Image" than lead user down a false path?) you get the following
PyAssertionError in the wxGUI command console:
   File "C:\Program Files\GRASS GIS 6.5.svn\Python27\lib
\site-packages\wx-2.8-msw-
unicode\wx\lib\filebrowsebutton.py", line 140, in OnChanged
self.changeCallback(evt)
   File "c:\Program Files\GRASS GIS
6.5.svn\etc\wxpython\psmap\dialogs.py", line 4272, in
OnDirChanged
self.OnImageSelectionChanged(None)
6.5.svn\etc\wxpython\psmap\dialogs.py", line 4304, in
self.ClearPreview()
6.5.svn\etc\wxpython\psmap\dialogs.py", line 4386, in
ClearPreview
mask = wx.Mask(buffer, wx.WHITE)
\site-packages\wx-2.8-msw-unicode\wx\_gdi.py", line 1212, in
__init__
_gdi_.Mask_swiginit(self,_gdi_.new_Mask(*args, **kwargs))
wx._core
PyAssertionError
C++ assertion "!bitmap.GetSelectedInto()" failed at
..\..\src\msw\bitmap.cpp(1509) in wxMask::Create(): bitmap
can't be selected in another DC
6.5.svn\etc\wxpython\psmap\frame.py", line 663, in
OnAddImage
dlg = ImageDialog(self, id = id, settings =
self.instruction)
6.5.svn\etc\wxpython\psmap\dialogs.py", line 4093, in
__init__
self.OnDirChanged(None)
OnDirChanged
self.ClearPreview()
ClearPreview
__init__
wx._core
PyAssertionError
and no image selection gui window. On my linux it works.
thanks,
Hamish
(trac logging itself out every 5 minutes! argh)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1959&gt;
Keywords: cartographic composer, wingrass | Platform: MSWindows XP
      Cpu: x86-32 |
Changes (by hamish):
  * keywords: cartographic composer => cartographic composer, wingrass
Ticket URL: <https://trac.osgeo.org/grass/ticket/1959#comment:1&gt;
      Cpu: x86-32 |
Comment(by annakrat):
Please try r56120.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1959#comment:2&gt;
      Cpu: x86-32 |
Replying to [comment:2 annakrat]:
> Please try r56120.
OK, this works. However we have different problem now. Apart from missing
refresh of the image in the dialog (hopefully fixed in r56133), I get
'IOError: error when accessing file' when I select eps file. See this
[http://mail.python.org/pipermail/image-sig/2004-April/002722.html
question]. This is problem for the eps files like grasslogo.eps or
compass_in/exterior.eps because they don't have 'showpage' command inside
unlike the newer eps north arrows. Adding this command would probably
solve the problem, but I am not sure if it safe. EPS
[http://partners.adobe.com/public/developer/en/ps/5002.EPSF_Spec.pdf
specification] allows it.
Another error when drawing eps in draft mode (r56134).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1959#comment:3&gt;
      Cpu: x86-32 |
Fixes r56120, r56121 (from #1960), r56133, r56134 seems to work, applied
to 64 and 7 (r56135, r56136).
Still there is the issue with 'showpage' related to certain eps files.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1959#comment:4&gt;
      Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:4 annakrat]:
thanks for the fixes, will try them out tomorrow.
I don't really enjoy the idea of modifying base data to work around a bug
in PIL, I'd much prefer if the python people were encouraged into fixing
their own bug. The whole point of EPS is to be a page-less version of
PostScript, so adding a form feed end-of-page command to it seems like an
ugly solution to me. Nonetheless, the `eps2eps` program adds showpages to
them, and the authors of that know better than I do about it. Does it work
to just do:
   echo " showpage" >> file.eps
What happens within the north arrow .eps files in ps/ps.map/decorations/
doesn't much bother me since I plan to replace them with native grass
symbol versions anyway. :slight_smile: (so they render more cleanly, can be used in
the regular GUI map display with d.graph, etc.)
btw, I've been meaning to respond properly to an old email: the symbol
sections grew somewhat organically from Radim's original set, rearranging
them into more logical categories in trunk would be a nice thing.
authoring them by hand is not so bad once you get used to it. see the
IconSymbols wiki page, and sketching with some graph paper then counting
off the coordinates helps a lot.
one day we'll get svg + eps + d.graph + grass symbols + ps.map all working
nicely together; it's been on the wish-list for a long time..
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1959#comment:5&gt;
      Cpu: x86-32 |
Comment(by hamish):
Fredrik Lundh wrote:
> I'll look into this for 1.1.5.
what version are we shipping with wingrass? (my local python-imaging on
linux is ver 1.1.7)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1959#comment:6&gt;
      Cpu: x86-32 |
Replying to [comment:6 hamish]:
linux is ver 1.1.7)
1.1.7 too. It's not clear to me why it behaves differently on Windows.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1959#comment:7&gt;
