GDAL
June 27, 2008, 11:00am
1
#196: wxGUI interface hangs, when adding maps to display
Reporter: rmatev | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Keywords: | Platform: MSWindows XP
Cpu: x86-32 |
When I set DEBUG=4 or DEBUG=5 and then add a vector map to map display 1
(which was empty), the whole wxpython interface hangs (before the map is
added). The same thing happens, if DEBUG is set to 0, 1, 2, or 3, then a
map is loaded into map display 1, then DEBUG is changed to 4, and the
display is refreshed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/196> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
2
Component: wxGUI | Version: 6.3.0
Resolution: | Keywords:
Platform: MSWindows XP | Cpu: x86-32
Changes (by rmatev):
* version: unspecified => 6.3.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/196#comment:1> ;
GDAL
August 16, 2008, 5:51pm
3
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by cmbarton):
* status: new => closed
* resolution: => fixed
Comment:
This is fixed in GRASS 6.4
Ticket URL: <http://trac.osgeo.org/grass/ticket/196#comment:2> ;
GDAL
August 16, 2008, 5:57pm
4
Type: defect | Status: reopened
Changes (by martinl):
* status: closed => reopened
* resolution: fixed =>
Comment:
This issue is still open... It hasn't been fixed AFAIK.
Ticket URL: <http://trac.osgeo.org/grass/ticket/196#comment:3> ;
GDAL
September 11, 2009, 6:02am
5
Comment (by cmbarton):
I've just tested this on 6.4 and 6.5 svn with Mac OSX. I have no problems.
No hanging with DEBUG=4 set. Is this still a problem for anyone else?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/196#comment:4> ;
GDAL
September 11, 2009, 6:39am
6
Comment (by martinl):
Replying to [comment:4 cmbarton]:
problems. No hanging with DEBUG=4 set. Is this still a problem for anyone
else?
yes,
g.gisenv set=DEBUG=5
* start wxGUI
* add new vector map layer
* display
wxGUI stops responding because of amount of debug messages redirected to
command output window.
Ticket URL: <http://trac.osgeo.org/grass/ticket/196#comment:5> ;
GDAL
September 27, 2009, 8:19pm
7
Is this something we want to fix or are even able to fix? This is not a
normal use scenario. How *could* it be fixed? Send output to a log?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/196#comment:6> ;
GDAL
July 7, 2010, 7:45am
8
Reporter: rmatev | Owner: grass-dev@…
Comment(by neteler):
Is this still an issue?
Ticket URL: <http://trac.osgeo.org/grass/ticket/196#comment:7> ;
GDAL
August 21, 2012, 10:44am
9
Changes (by neteler):
* status: reopened => closed
Comment:
No answer, closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/196#comment:8> ;
