#1961: wxNVIZ: error if no raster map selected
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: wxnviz | Platform: All
Cpu: x86-64 |
testing wxNVIZ in latest 6.5svn, I get an error and 100% CPU use if I
select '3D view' in the map display window with just a vector map
selected. (also tried with a 3D vector map, same thing) happens both on my
linux and Wingrass-VM. It's recoverable once you switch back to '2D view'
mode.
one possible solution is in the case of no raster tell nviz to create a
new constant surface at z=0 with 50% transparency. (or at least that's the
trick with tcl/tk nviz + no raster to drape things on)
traceback from wxgui module output window:
Starting 3D view mode...
Vector map <roads@PERMANENT> loaded (746 features)
File "/home/hamish/src/grass/svn/grass65/dist.x86_64
-unknown-linux-gnu/etc/wxpython/nviz/mapwindow.py", line
366, in OnPaint
self.DoPaint()
383, in DoPaint
self.lmgr.nviz.UpdatePage('view')
-unknown-linux-gnu/etc/wxpython/nviz/tools.py", line 4233,
in UpdatePage
hmin,hmax)
File "/usr/lib64/python2.6/dist-
packages/wx-2.8-gtk2-unicode/wx/_controls.py", line 2692, in
SetRange
return _controls_.Slider_SetRange(*args, **kwargs)
OverflowError
long int too large to convert to int
366, in OnPaint
self.DoPaint()
383, in DoPaint
in UpdatePage
hmin,hmax)
SetRange
OverflowError
366, in OnPaint
self.DoPaint()
383, in DoPaint
in UpdatePage
hmin,hmax)
SetRange
OverflowError
cannot convert float infinity to integer
366, in OnPaint
self.DoPaint()
383, in DoPaint
in UpdatePage
hmin,hmax)
SetRange
OverflowError
366, in OnPaint
self.DoPaint()
383, in DoPaint
in UpdatePage
hmin,hmax)
SetRange
OverflowError
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1961>
