#1967: wxPy loc'n wiz: doesn't allow ellipsoid without datum
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: location wizard, ellipsoid | Platform: All
Cpu: All |
the location wizard won't like you create a location unless you set a
datum.
example: start grass with the wxGUI, click on loc'n wizard, click on
Select coord sys params from list, proj code: ll, "Select datum or
ellipsoid (next page)" -> '''Ellipsoid only''', ellipsoid code: sphere,
WARNING: Datum <unknown> not recognised by GRASS and no parameters found
ERROR: Invalid datum code <>
the warning may be harmless (expected), but the ERROR is probably the loc
wiz passing the datum= option unconditionally, which we can easily fix.
adding a G_debug() statement in there shows:
D0/0: proj4string=[+proj=longlat +lat_0=0.0 +lon_0=0.0 +ellps=sphere
+a=6370997.000 +e=0.0 +no_defs +no_defs]
(I don't think related, but again note the two '+no_defs')
Once you click ok to the warning pop-up it goes away and takes you to the
Summary page, but the PROJ.4 definition is blank, and so it won't let you
finish.
this is somewhat related to #1849 (r56093, r56143), and most likely the
real trouble earlier noticed in #1513/comment 3, but in the latter case I
mistook the cause for being specific to the new Planetary ellipsoid
selection tool.
It is unclear to me if proj 4.8.0 will automatically try to fill in datum
details if you left it blank, but I get the same breakage w/ 4.7.0 and
4.8.0 proj4s.
thanks for the diagnosis Yann.
using the text startup and g.setproj all should be ok.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1967>
