#1968: traceback error in wxgui goutput.py on save command output
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 6.4.3
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: All
Cpu: All |
I get a traceback message in the terminal when I click to save the command
window output from a module GUI. Both on linux and MS Windows, 6.4.3svn
and devbr6 (but not in trunk).
* start a grass command line session
* bring up a module GUI: g.version --ui
* select the -b build info flag
* click run (note scrollbar doesn't cover full ./configure line unless
you highlight drag the text)
* Output window -> Save, pick filename, ok
then,
File "/home/hamish/src/grass/svn/relbr_6_4/dist.x86_64-unknown-linux-
gnu/etc/wxpython/gui_core/goutput.py", line 679, in OnOutputSave
self.parent.SetStatusText(_("Command output saved into '%s'") % path)
AttributeError: 'CmdPanel' object has no attribute 'SetStatusText'
but the file is saved ok.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1968>
