#1971: 64bit LFS support for G_ftell() and PRI_OFF_T gis.h
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: LibGIS | Version: svn-develbranch6
Keywords: r.in.bin, LFS, G_ftell(), PRI_OFF_T | Platform: Linux
Cpu: x86-64 |
as reported on the users' ML, r.in.bin is failing for input files bigger
than 2GB. thread: "ERROR: Bytes do not match file size with r.in.bin (but
file size is correct!!)"
http://thread.gmane.org/gmane.comp.gis.grass.user/47202
It works in trunk, but not 6.x. Just after 6.4.1 was released r.in.bin got
upgraded to off_t, but PRI_OFF_T in GRASS 6 set by gis.h remains as "ld"
because
`LFS_CFLAGS = -D_FILE_OFFSET_BITS=64`
is missing from Grass.make (it is there in G7). That may just be the
overflow in the error message though, I think the real problem is
G_ftell() is always returning int, even when ftello() should be returning
off_t.
fwiw in G6 only the flags for wxWidgets get D_FILE_OFFSET'd.
In G7 PRI_OFF_T is "lld" and r.in.bin works on a >2GB test file.
here's a little Matlab/Octave code to make one:
%%%% make a >2GB binary data file
fd1 = fopen('lfs_test.bin', 'w');
rows=19450
cols=29404
for i = 1:rows
row_content = [1:cols] * sqrt(i);
fwrite(fd1, row_content, 'real*4');
end
fclose(fd1)
and import command:
$ ls -l lfs_test.bin
-rw-r--r-- 1 hamish hamish 2287631200 May 10 12:43 lfs_test.bin
GRASS> r.in.bin -f input=lfs_test.bin output=outputmap bytes=4 \
n=51:05:20.4N s=41:21:50.4N w=5:08:31.2W e=9:33:36E \
r=19450 c=29404 anull=-9999.0
the error in GRASS 6 is:
WARNING: File Size -2007336096 ... Total Bytes 2287631200
This is a 64bit system, and `GRASS6> g.version -b | tr ' ' '\n'` has the
--enable-64bit option, but I'm not really sure why that's needed, as
autoconf already knows the platform. (for cross-compiling from 32bit?)
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1971>
