[GRASS-dev] [GRASS GIS] #1974: buffer overflow in v.to.rast
Reporter: mgeeves | Owner: grass-dev@…
     Type: defect | Status: new
Priority: minor | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: | Platform: All
      Cpu: All |
The issue in bug #800 is also present in v.to.rast, long names which are >
the 80 char RECORD_LEN causes a buffer overflow when writing history
sprintf -> G_snprintf swap needed
(still present in develbranch_6)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1974&gt;
Keywords: v.to.rast | Platform: All
      Cpu: All |
Changes (by hamish):
  * keywords: => v.to.rast
Comment:
works for me in devbr6, and there's no difference in the v.to.rast code
between that and relbr64.
r.mapcalc
"map0123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789
= 103"
r.to.vect
in=map0123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789
out=vmap0123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789
    fea=area
v.to.rast
in=vmap0123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789
out=rvmap0123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789
    use=val val=105
r.info ...
  | v.to.rast
input="vmap01234567890123456789012345678901234567890123456\ |
  | 78901234567890123456789012345678901234567890123456789" layer=1
type=\ |
  | "point,line,area"
output="rvmap0123456789012345678901234567890123456\ |
  | 789012345678901234567890123456789012345678901234567890123456789"
use\ |
  | ="val" value=105 rows=4096
can you provide more details about how to reproduce it?
which platform?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1974#comment:1&gt;
      Cpu: All |
Comment(by mgeeves):
Hi Hamish,
Sure - this is on Ubuntu 12.04 LTS, compiled from grass-6.4.2.tar.gz
Reproducible here from two identical vectors:
v.in.ascii fs=, input=-
output=p1234567890123456789012345678901234567890123456789012
0.1,51
<CTRL+D>
output=p12345678901234567890123456789012345678901234567890123
0.1,51
<CTRL+D>
This one works
v.to.rast input=p1234567890123456789012345678901234567890123456789012
output=r_ok use=val
This one fails
v.to.rast input=p12345678901234567890123456789012345678901234567890123
output=r_nok use=val
*** buffer overflow detected ***: v.to.rast terminated
======= Backtrace: =========
/lib/i386-linux-gnu/libc.so.6(__fortify_fail+0x45)[0xb763bdd5]
/lib/i386-linux-gnu/libc.so.6(+0xfebaa)[0xb763abaa]
/lib/i386-linux-gnu/libc.so.6(+0xfe208)[0xb763a208]
/lib/i386-linux-gnu/libc.so.6(_IO_default_xsputn+0x91)[0xb75ad461]
/lib/i386-linux-gnu/libc.so.6(_IO_vfprintf+0x53f0)[0xb7581be0]
/lib/i386-linux-gnu/libc.so.6(__vsprintf_chk+0xc9)[0xb763a2d9]
/lib/i386-linux-gnu/libc.so.6(__sprintf_chk+0x2f)[0xb763a1ef]
v.to.rast(update_hist+0xbd)[0x804b7ad]
v.to.rast(vect_to_rast+0x438)[0x804cd98]
v.to.rast(main+0x302)[0x804a432]
/lib/i386-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0xb75554d3]
v.to.rast[0x804a4f9]
<SNIP>
Hopefully I've not done something daft elsewhere!
Mike
Ticket URL: <https://trac.osgeo.org/grass/ticket/1974#comment:2&gt;
      Cpu: All |
Comment(by hamish):
I works for me on debian, 6.4.2, 6.4.3svn, and 6.5svn. Also tested
6.4.3svn on ubuntu 12.04 LTS.
Can you try building 6.4.3rc3? there were a number of overflow bugs fixed
in v.to.rast since 6.4.2 to do with labels, which are now fixed. it could
have been something related to that.
a buffer overflow is pretty much always the programmer's fault.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1974#comment:3&gt;
      Cpu: All |
Hi Hamish,
Odd, I'm still seeing the same problem in grass-6.4.3RC3. Re being daft I
mostly meant having old bits from previous SVN builds conflicting. To rule
that out I've tried building another vm with vmbuilder (defaults apart
from adding in a few bits like the sshd and deb-src repos), then an
apt-get build-dep grass
and building from grass-6.4.3RC3.tar.gz with:
./configure --with-proj-share=/usr/share/proj --with-tcltk-
includes=/usr/include/tcl8.5
Installing using checkinstall with defaults
Same result, buffer overrun!
Note the raster is actually generated and displays ok, it just displays
the overflow error and doesn't record to hist
After changing the code in support.c to use G_snprintf, it doesn't error
for me any more..
Mike
Ticket URL: <https://trac.osgeo.org/grass/ticket/1974#comment:4&gt;
      Cpu: All |
Comment(by hamish):
ok, I could reproduce it in a package build after making the name a bit
longer, I guess the unoptimized 'gcc -g' in my source build was zeroing
all memory or so, shrug.
fixed in devbr6 in r56254. please everyone test so it can be applied to
6.4svn in time for the release.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1974#comment:5&gt;
      Cpu: All |
Looking better for me, thanks!
Ticket URL: <http://trac.osgeo.org/grass/ticket/1974#comment:6&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.to.rast
  Platform: All | Cpu: All
  * status: new => closed
  * resolution: => fixed
Comment:
fix backported to relbr64 in r56744.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1974#comment:7&gt;
