#1978: module GUIs: "or enter values interactively" should be opt-in
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: svn-trunk
Keywords: parser | Platform: All
Cpu: All |
for the G_standard_input for input files, the auto-generated wx module
GUIs are always asking "or enter values interactively" whenever
G_define_standard_option(G_OPT_F_INPUT) is present.
Since that makes no sense for binary input files, and anything automatic
should err on the side of not being weird, the interactive version should
be opt-in -- the programmer should have to use a special gisprompt in
those cases. (e.g. r.in.gdal, v.in.ogr, r.in.bin (G6.x), r.in.mat, ...)
fwiw section 12.16.5.2.4 of the grass5 programmer's manual has a full
description of what the a,b,c options of gisprompt were originally
designed to be,
12.16.5.2.4 gisprompt Member
The gisprompt Option structure item requires a bit more description. The
three comma-separated (no spaces allowed) sub-arguments are defned as
follows:
First argument:
"old" results in a call to the GRASS library subroutine G_ask_old, "new"
to G_ask_new, "any" to G_ask_any, and "mapset" to G_ask_in_mapset.
Second argument:
This is identical to the "element" argument in the above subroutine
calls. It specifes a directory inside the mapset that may contain the
user's response.
Third argument:
Identical to the "prompt" argument in the above subroutine calls. This is
a string presented to the user that describes the type of data element
being requested.
see lib/gis/ask.c for the "above subroutine calls".
I first considered to mangling all the gisprompts by hand to stop the
"interactive" text box but keep the Browse button, but then it occurs to
me that the gui parser is the problem, not the modules. (also it seems the
above a,b,c have been continually redefined since the tcltk gui days, so
we should better sort out what it means now if gisprompt is to be
different in grass7)
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1978>
