#198: v.in.ascii: column scanning is borked
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Vector | Version: svn-develbranch6
Keywords: v.in.ascii | Platform: All
Cpu: All |
this bug is related to the old RT bugs 2763 and 5209.
http://intevation.de/rt/webrt?serial_num=2763
http://intevation.de/rt/webrt?serial_num=5209
and the clumsy empty last-column work-around in v.in.gpsbabel:
http://trac.osgeo.org/grass/browser/grass/trunk/scripts/v.in.gpsbabel/v.in.gpsbabel#L298
"FIXME: if last field (comments) is empty it causes a not-enough fields
error in v.in.ascii"
The column type scanning step in v.in.ascii's points mode no longer
accepts empty columns as NULL, and imported tables have columns truncated.
Note that passing empty values in double columns works in GRASS 6.2.3!
It would be nice to allow numeric columns as empty or 'NULL' for an empty
record, and allow "nan" or "inf" without the scanning function deciding
that the column contains strings.
(For varchar columns the word 'NULL' should not be stripped however)
Input file:
cat << EOF > test.dat
cat|x|y|name|value|count
1|2.3|4.5|Foo|3.1415|4
2|2.4|4.6|Bar|||
EOF
Import without column declaration:
G64svn> v.in.ascii in=test.dat out=test_null_import skip=1 \
cat=1 x=2 y=3 --verbose
Scanning input for column types...
Maximum input row length: 25
Maximum number of columns: 6
Minimum number of columns: 6
Column: 1 type: integer
Column: 2 type: double
Column: 3 type: double
Column: 4 type: string length: 3
Column: 5 type: string length: 0
Column: 6 type: string length: 0
Importing points...
Populating table...
Building topology for vector map <test_null_import>...
2 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built
Number of nodes : 2
Number of primitives: 2
Number of points : 2
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
v.in.ascii complete.
G64svn> v.info -c test_null_import
Displaying column types/names for database connection of layer 1:
INTEGER|int_1
DOUBLE PRECISION|dbl_1
DOUBLE PRECISION|dbl_2
CHARACTER|str_1
* what happened to columns 5 and 6?
* Columns 5 and 6 incorrectly scanned as (empty) "string" type.
Also, I am not sure if hiding the column scanning result behind --verbose
mode is advisable, given that it is buggy and it is the first line of
defense when the input file contains typos.
Import with column declaration:
cat=1 x=2 y=3 --verbose \
columns='cat int, x double, y double, name varchar(10), value
double, count int'
WARNING: Table <test_null_import> linked to vector map <test_null_import>
does not exist
ERROR: Column number 5 defined as double has string values
* in addition to previous errors the "table does not exist" warning's
meaning is a mystery.
changing the empty {{{"||"}}} to "|NULL|" doesn't help, the scanning step
declares it as a string column (length: 4) and refuses to continue.
this is important code, so tread with greatest care.....
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/198>
