#1980: Multiple time stamp support for raster and 3D raster maps
Reporter: huhabla | Owner: grass-dev@…
Component: LibGIS | Version: svn-trunk
Keywords: timestamp, multiple, temporal, category, layer | Platform: All
Cpu: All |
Comment(by huhabla):
The idea is to have multiple timestampsthat might be time instances
(datetime) or time intervals (datetime/datetime) for raster and 3D raster
maps.
This is an example from the temporal framework how this works with vector
layer support:
#!sh
# First we create random vector map
v.random output=sites n=100 zmin=0 zmax=100 column=waterlevel
# Adding new layer with categories
v.category input=sites out=sites_2001_2006 option=transfer
layer=1,2,3,4,5,6
# Lets copy the first table to layer specific tables
db.copy from_table=sites to_table=sites_2002
db.copy from_table=sites to_table=sites_2003
db.copy from_table=sites to_table=sites_2004
db.copy from_table=sites to_table=sites_2005
db.copy from_table=sites to_table=sites_2006
# Then we add the tables to the layer
v.db.addtable map=sites table=sites_2002 layer=2
v.db.addtable map=sites table=sites_2003 layer=3
v.db.addtable map=sites table=sites_2004 layer=4
v.db.addtable map=sites table=sites_2005 layer=5
v.db.addtable map=sites table=sites_2006 layer=6
# We create a file to store the vector:layer ids for
# temporal GIS registration. For each layer of the vector map
# a different timestamp is defined. In this case we define time intervals
# with one year granularity
cat > timestamps.txt << EOF
sites_2001_2006:1|2001-01-01|2002-01-01
sites_2001_2006:2|2002-01-01|2003-01-01
sites_2001_2006:3|2003-01-01|2004-01-01
sites_2001_2006:4|2004-01-01|2005-01-01
sites_2001_2006:5|2005-01-01|2006-01-01
sites_2001_2006:6|2006-01-01|2007-01-01
EOF
# We create a new space time vector dataset
t.create type=stvds temporaltype=absolute output=mysites title="A test"
descr="A test"
# Lets register the vector maps
t.register -i type=vect input=mysites file=timestamps.txt
# Some info about the new dataset
t.info type=stvds input=mysites
+-------------------- Space Time Vector Dataset
+-------------------- Basic information
| Id: ........................ mysites@PERMANENT
| Mapset: .................... PERMANENT
| Creator: ................... soeren
| Creation time: ............. 2013-05-29 13:34:26.924717
| Temporal type: ............. absolute
| Semantic type:.............. mean
+-------------------- Absolute time
| Start time:................. 2001-01-01 00:00:00
| End time:................... 2007-01-01 00:00:00
| Granularity:................ 1 year
| Temporal type of maps:...... interval
+-------------------- Spatial extent
| North:...................... 79.694475
| South:...................... 1.27134
| East:.. .................... 119.978137
| West:....................... 0.90041
| Top:........................ 0.0
| Bottom:..................... 0.0
+-------------------- Metadata information
| Vector register table:...... mysites_PERMANENT_vector_register
| Number of points ........... 600
| Number of lines ............ 0
| Number of boundaries ....... 0
| Number of centroids ........ 0
| Number of faces ............ 0
| Number of kernels .......... 0
| Number of primitives ....... 600
| Number of nodes ............ 0
| Number of areas ............ 0
| Number of islands .......... 0
| Number of holes ............ 0
| Number of volumes .......... 0
| Number of registered maps:.. 6
| Title:
| A test
| Description:
| A test
| Command history:
| - 2013-05-29 13:34:26 -
| t.create type="stvds" temporaltype="absolute"
| output="mysites" title="A test" descr="A test"
| - 2013-05-29 13:36:34 -
| t.register -i type="vect" input="mysites"
| file="timestamps.txt"
# List all sites in the stvds mysites
t.vect.list -h input=mysites
id name layer mapset start_time end_time
sites_2001_2006:1@PERMANENT sites_2001_2006 1 PERMANENT
2001-01-01 00:00:00 2002-01-01 00:00:00
sites_2001_2006:2@PERMANENT sites_2001_2006 2 PERMANENT
2002-01-01 00:00:00 2003-01-01 00:00:00
sites_2001_2006:3@PERMANENT sites_2001_2006 3 PERMANENT
2003-01-01 00:00:00 2004-01-01 00:00:00
sites_2001_2006:4@PERMANENT sites_2001_2006 4 PERMANENT
2004-01-01 00:00:00 2005-01-01 00:00:00
sites_2001_2006:5@PERMANENT sites_2001_2006 5 PERMANENT
2005-01-01 00:00:00 2006-01-01 00:00:00
sites_2001_2006:6@PERMANENT sites_2001_2006 6 PERMANENT
2006-01-01 00:00:00 2007-01-01 00:00:00
t.vect.list -h input=mysites columns=name,layer,start_time
where="start_time >= '2003-01-01'"
name layer start_time
sites_2001_2006 3 2003-01-01 00:00:00
sites_2001_2006 4 2004-01-01 00:00:00
sites_2001_2006 5 2005-01-01 00:00:00
sites_2001_2006 6 2006-01-01 00:00:00
Ticket URL: <http://trac.osgeo.org/grass/ticket/1980#comment:2>
