[GRASS-dev] [GRASS GIS] #1982: v.rast.stats: running generates "Unable to fetch interface description for command" error
command" error
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: v.rast.stats | Platform: MSWindows 7
      Cpu: Unspecified |
Recent winGRASS 7 standalone installer - running v.rast.stats
generates this error:
   File "C:\Program Files\GRASS GIS
7.0.svn\etc\gui\wxpython\lmgr\frame.py", line 737, in
OnMenuCmd
cmd = self.GetMenuCmd(event)
7.0.svn\etc\gui\wxpython\lmgr\frame.py", line 722, in
GetMenuCmd
input = GUI().GetCommandInputMapParamKey(cmdlist[0])
7.0.svn\etc\gui\wxpython\gui_core\forms.py", line 2296, in
tree =
etree.fromstring(gtask.get_interface_description(cmd))
7.0.svn\etc\python\grass\script\task.py", line 464, in
"\n\nDetails: %(det)s") % { 'cmd' : cmd, 'det' :
decode(cmderr) }
grass.script.core
ScriptError
'v.rast.stats'.
Details: C:\Program Files\GRASS GIS
7.0.svn\extrabin\python.exe: can't open file 'v.rast.stats':
[Errno 2] No such file or directory
Ticket URL: <http://trac.osgeo.org/grass/ticket/1982&gt;
command" error
      Cpu: Unspecified |
Comment(by annakrat):
You run it from menu? (It is always better to include the information
where you run the command from.) Is the version recent enough? Are there
any other python scripts not running?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1982#comment:1&gt;
command" error
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:1 annakrat]:
Yes (it was not my own machine but from a course participant)
Two days old.
> Are there any other python scripts not running?
Other look fine. It is the v.rast.stats script which gave problems on
various
machines. From the error I don't know what to look for or check on the
user's
machine.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1982#comment:2&gt;
command" error
      Cpu: Unspecified |
Comment(by hamish):
perhaps g.parser is looking for "v.rast.stats" but only "v.rast.stats.py"
exists in the %PATH%, and it is missing the ".py" extension association?
(that only works in the DOSbox window, not the MSys one AFAIK, and GRASS7
doesn't have the .bat file wrappers in bin/)
what does "set" say at the GRASS cmd.exe prompt? is ";.PY" known?
do other python scripts like r3.in.xyz work there?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1982#comment:3&gt;
command" error
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.rast.stats
  Platform: MSWindows 7 | Cpu: Unspecified
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Comment:
Tested, seems to be fixed by relatively recent changes in calling Python
scripts.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1982#comment:4&gt;
