[GRASS-dev] [GRASS GIS] #1995: wxPy loc'n wiz: datum transform "0" do nothing still gets default terms set
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Projections/Datums | Version: svn-trunk
Keywords: location wizard, g.proj | Platform: All
      Cpu: All |
moved here from #1849 comments.
if you create a new location and specify a datum, but ask for datum
transform opt "0" don't specify terms, it helpfully picks one for you
without asking.
if you use +proj terms to define the location you do see the default terms
in the loc'n wizard summary page, but not the final PROJ_INFO file (where
it counts).
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1995&gt;
