[GRASS-dev] [GRASS GIS] #1997: i.landsat.toar for grass-dev is missing the option for landsat8
Reporter: vesnikos | Owner: grass-dev@…
Component: Imagery | Version: unspecified
Keywords: i.landsat.toar | Platform: Linux
      Cpu: Unspecified |
I just noticed that i.landsat.toar module for grass7 is missing the option
for the new landsat8 satelite , while i.landsat.toar for grass64 has is.
for reference for grass64 the sensor id is sensor=ot8 when invoking the
module.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1997&gt;
     Type: defect | Status: new
      Cpu: Unspecified |
Changes (by neteler):
  * type: enhancement => defect
Comment:
The updates (fixes) in GRASS 7 where not backported properly to G6:
http://trac.osgeo.org/grass/log/grass/trunk/imagery/i.landsat.toar
(r54898,r54904,r54907,r54910,r55068,r55114,r55499)
which prevented the following bugfixes provided by the original
author to be applied to the version in GRASS 7:
http://trac.osgeo.org/grass/log/grass/branches/releasebranch_6_4/imagery/i.landsat.toar
(r53589,r54844,r55376)
Essentially this fork needs to be consolidated.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1997#comment:1&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:1 neteler]:
i.landsat.toar is now consolidated across all branches. The only
difference is an option in trunk to print out selected metadata, absent in
GRASS 6.x.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1997#comment:2&gt;
Component: Imagery | Version: svn-trunk
Keywords: i.landsat.toar | Platform: All
      Cpu: Unspecified |
  * platform: Linux => All
  * version: unspecified => svn-trunk
Comment:
For the record: r56905, r56906, r56907, r56908
vesnikos, please close the ticket if it works for you
Ticket URL: <https://trac.osgeo.org/grass/ticket/1997#comment:3&gt;
      Cpu: Unspecified |
Comment(by nikosa):
Replying to [comment:3 neteler]:
It works for me (tried with 56906). Tested using the Landsat 8 scene (and
respective MTL file) LC81260592013169LGN00(_MTL.txt).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1997#comment:4&gt;
      Cpu: Unspecified |
Comment(by nikosa):
Replying to [comment:4 nikosa]:
Retried with revision=56932M. All fine.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1997#comment:5&gt;
      Cpu: Unspecified |
Comment(by vesnikos):
some minor bugs during my tests:
1) Cosmetic typo at the description of sensor parameter:
   It says "Required only if 'metfile' not given (recommended by sanity)"
   should be ""Required only if 'metfile' not given (recommended for
sanity)
2) Band8 (panchomatic) has my nature 15m res. The algorithm uses the
regions resolution , and you cannot do anything to override it.
3) timestamp in r.info reads none, the date of acquisition is in the
metadata, so it should be properly implemented
eg: r.timestamp map=LC81840322013143LGN03_B10.toarr.1 date="$(date
-d'$DATE_ACQUIRED $SCENE_CENTER_TIME' -u +'%d %b %Y %H:%M:%S.%N %z')"
Ticket URL: <http://trac.osgeo.org/grass/ticket/1997#comment:6&gt;
      Cpu: Unspecified |
Comment(by nikosa):
Replying to [comment:6 vesnikos]:
You can set the region resolution to the desired one! In my scripts I do
that. Maybe in this case an exception could be done and let the module
handle this?
This would be also nice!
You can get the date using
i.landsat.toar -p metfile=MTLFile.txt lsatmet=date
and the ''decimal'' time
i.landsat.toar -p metfile=MTLFile.txt lsatmet=time
though, the "input_prefix=Dummy" and "output_prefix=Dummy" must be
defined.
For the records, if you import Landsat bands using the script found in
GRASS-Wiki
[http://grasswiki.osgeo.org/wiki/LANDSAT#Automated_data_import], the
timestamp is set correctly. However, i.landsat.toar does not take care to
copy this over. Even, the right way would be to grep the info from the
MTL file directly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1997#comment:7&gt;
      Cpu: Unspecified |
Comment(by nikosa):
> Replying to [vesnikos]:
Maybe you can close this ticket as i.landsat.toar knows about Landsat8
now! We can open a new ticket for the other issues.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1997#comment:8&gt;
      Cpu: Unspecified |
Comment(by hamish):
> 1) ... (recommended for sanity)
done in all branches
Ticket URL: <https://trac.osgeo.org/grass/ticket/1997#comment:9&gt;
Niko,
would you mind checking it this ticket is still "open" for you?
Nikos
Reporter: vesnikos | Owner: grass-dev@… Type: defect
   | Status: new Priority: normal | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk Keywords:
i.landsat.toar | Platform: All Cpu: Unspecified |
sanity)
      Cpu: Unspecified |
Comment(by nikosa):
Replying to [comment:7 nikosa]:
do that. Maybe in this case an exception could be done and let the module
handle this?
This look more important than I thought in the beginning. Indeed, one
needs to work-around that issue since there is no way to preserve the
15m-s of Band 8 using (the current) i.landsat.toar in one go.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1997#comment:10&gt;
Yeah its still open - It shouldn’t since the main problem is fixed. I’ll open a new ticket for the the resolution bug.
BTW, I have made a script that does what i.landsat.toar does, only that its fixed in that regard. I’ll be more than happy to share it if someone needs it!
N
Cpu: Unspecified |
Comment(by nikosa):
  1. Band8 (panchomatic) has my nature 15m res. The algorithm uses the
handle this?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1997#comment:10>
new ticket about the resolution issue:
https://trac.osgeo.org/grass/ticket/2089
N
Cpu: Unspecified |
Comment(by nikosa):
handle this?
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:10 nikosa]:
New ticket about the resolution issue: #2089
Ticket URL: <https://trac.osgeo.org/grass/ticket/1997#comment:11&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: i.landsat.toar
  Platform: All | Cpu: Unspecified
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:8 nikosa]:
now!
Yes, closing (and also the other issue has been fixed).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1997#comment:12&gt;
