[GRASS-dev] [GRASS GIS] #1999: r.mask with NULL map doesn't work
Reporter: ferrouswheel | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Raster | Version: svn-develbranch6
Keywords: | Platform: Linux
      Cpu: Unspecified |
When presenting r.mask with map containing all NULL values, it accepts the
map and sets it as a mask.
However, despite setting it as a mask, it does nothing. Instead of
preventing all data from being available to read, it allows all data to be
read.
This is counter-intuitive. r.mask should either complain when setting a
mask of all NULL values, or it should make it impossible to access any
data (because there are no non-NULL cells in the source map).
While one might question the use of a mask of all NULL cells, this can
easily occur when scripting GRASS commands.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1999&gt;
Keywords: r.mask | Platform: Linux
      Cpu: Unspecified |
Changes (by hamish):
  * keywords: => r.mask
Comment:
I can reproduce it,
setup:
# fully null input map for r.mask:
G65> g.region -d
G65> r.mapcalc "allnull = null()"
G65> r.info -r allnull
min=NULL
max=NULL
btw r.univar is broken for that, with --quiet you get no output at all!
what r.mask does:
G65> echo "* = 1" | r.reclass input=allnull output=MASK.test
G65> r.info -r MASK.test
min=1
max=1
again, this time with partially null input map for r.mask:
G65> r.mapcalc "partnull = if(row() > 100, row(), null())"
r.info -r partnull
min=101
max=477
echo "* = 1" | r.reclass input=partnull output=partial.MASK.test
G65> r.univar partial.MASK.test
total null and non-null cells: 302418
total null cells: 63400
n: 239018
minimum: 1
maximum: 1
so it is a quirk of how r.reclass works. I'm not sure, but it seems like
it could be an intended feature. One which should be documented in the man
page of course...
Keeping r.reclass as-is, here's a possible solution:
eval `r.info -r allnull`
if [ "$min" = "NULL" -a "$max" = "NULL" ] ; then
    RECLASS_TO="NULL"
else
    RECLASS_TO="1"
fi
echo "* = $RECLASS_TO" | r.reclass input="$GIS_OPT_INPUT" output=MASK
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1999#comment:1&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:1 hamish]:
> what r.mask does:
min=1
max=1
The range file generated by r.reclass is based upon the range of values in
the reclass table, regardless of the values present in the base map. E.g.:
$ r.mapcalc --o 'foo = 2'
$ r.reclass --o in=foo out=bar rules=-
Enter rule(s), "end" when done, "help" if you need it
CELL: Data range is 2 to 2
> 1 = 1
> 2 = 2
> 3 = 3
> end
$ r.info -r bar
min=1
max=3
However, that isn't the real problem here.
1. A map which is a reclass of an all-null map is read as all-null:
$ echo "* = 1" | r.reclass input=allnull output=testmask rules=-
$ r.mapcalc --o 'foo = testmask'
$ r.info -r foo
min=NULL
max=NULL
2. A MASK map which is a reclass of an all-null map doesn't mask anything
out:
$ echo "* = 1" | r.reclass input=allnull output=MASK rules=-
$ r.mapcalc --o 'foo = elevation.dem'
$ g.remove rast=MASK
$ r.info -r foo
min=1066
max=1840
3. A (non-reclass) all-null MASK map masks everything out:
$ r.mapcalc 'MASK = allnull'
$ r.info -r foo
min=NULL
max=NULL
Clearly, the code in lib/raster/get_row.c which reads a MASK map doesn't
handle reclass maps correctly.
Specifically, embed_mask() calls get_map_row_nomask() then, if it's a
reclass map, do_reclass_int(). Finally, any cell whose value is zero is
marked as null.
However, get_map_row_nomask() doesn't embed nulls (so any nulls will be
read as zero). When the mask isn't a reclass, this works okay, as nulls
are stored with zero as the cell value. But do_reclass_int() expects nulls
to have been embedded; a zero will be treated as such and reclassed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1999#comment:2&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:2 glynn]:
Possible fix:
--- lib/raster/get_row.c (revision 56625)
+++ lib/raster/get_row.c (working copy)
@@ -919,11 +919,13 @@
         return;
- if (R__.fileinfo[R__.mask_fd].reclass_flag)
+ if (R__.fileinfo[R__.mask_fd].reclass_flag) {
+ embed_nulls(R__.mask_fd, mask_buf, row, CELL_TYPE, 0, 0);
         do_reclass_int(R__.mask_fd, mask_buf, 1);
      for (i = 0; i < R__.rd_window.cols; i++)
- if (mask_buf[i] == 0)
+ if (mask_buf[i] == 0 || Rast_is_c_null_value(&mask_buf[i]))
             flags[i] = 1;
      G__freea(mask_buf);
Ticket URL: <http://trac.osgeo.org/grass/ticket/1999#comment:3&gt;
Priority: normal | Milestone: 6.4.4
      Cpu: Unspecified |
Changes (by neteler):
  * milestone: 6.4.3 => 6.4.4
Comment:
Replying to [comment:3 glynn]:
doesn't handle reclass maps correctly.
> Possible fix:
Glynn, do you plan to apply that to G7? And is a backport
possible/recommended?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1999#comment:4&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:4 neteler]:
Try r58723.
> And is a backport possible/recommended?
I have no idea.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1999#comment:5&gt;
