#200: v.rast.stats referring to deprecated function
Reporter: carlo | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.1
Component: Vector | Version: 6.3.0
Keywords: | Platform: All
Cpu: All |
v.rast.stats currently does not work as the cored refers to the deprecated
function r.cats (line 157). Should be changed to r.category
Type: defect | Status: closed
Resolution: duplicate | Keywords:
Platform: All | Cpu: All
Changes (by hamish):
* status: new => closed
* resolution: => duplicate
Comment:
Already fixed in devbr6 and trunk; see trac bug #161.
AFAIK this was only a problem in an older Windows build where the shell
script wrappers that provided backwards compatibility with the old module
name were missing.
