#2004: wxgui: ctrl-t to tile layer manager and map window full screen
Reporter: hamish | Owner: grass-dev@…
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: svn-trunk
Keywords: window layout | Platform: All
Cpu: All |
it would be very handy to make ctrl-t tile the layer manager and map
window side by side, full screen.
the idea is to read the desktop size in pixels, split it up ~1.7:1 ratio
with the wider (squarer) map display on the right, but if that makes the
layer manager wider than 700px max it out at that and make the map window
wider to fill in the gap between them.
On my system with default (AFAIK) fonts 700px wide layer manager window
gets the output window tab and the '>>> ' python prompt tab to allow 80
chars of text to fit without wrapping. (e.g. for r.info report output)
maybe if multiple map windows are open tile them top-to-bottom on the
right side.
I'm not sure if it can control the launching Terminal prompt (xterm)
window, maybe the best we could do there is split the left-side upper
2/3rds for the layer manager and leave the bottom 1/3rd empty for the user
to move the window there themselves? (or just ignore it and make the layer
manager be full-height on the left side)
Cpu: All |
Comment(by hamish):
attached is come code to tile the map windows, but I'm not sure where it
should go or how to bind that to ctrl-t in gui_core/forms.py. Ideally the
keybinding should work from the layer manager or any map window. (I note
that ctrl-q and ctrl-w only work from the layer manager window currently,
it would be good to extend that too)
Also the elif cases could probably be better collapsed into something a
bit more elegant, it's just proof of concept. No idea how it behaves on a
dual monitor setup.
Finally, I notice that you get a beyond index traceback error after you
open a fifth+ map display window.
Priority: normal | Milestone: 7.1.0
Cpu: All |
Changes (by annakrat):
* milestone: 6.4.5 => 7.1.0
Comment:
Try r60971 for fullscreen map display. Works also for
g.gui.mapswipe/iclass/gcp. I am not sure if we want to keep the toolbars
or not. Showing them would be more consistent with other applications but
I don't think they are necessary when we can move the map view with mouse
only.
Cpu: All |
Comment(by hamish):
Replying to [comment:3 annakrat]:
awesome, thank you.
> I am not sure if we want to keep the toolbars or not. Showing them
> would be more consistent with other applications but I don't think
> they are necessary when we can move the map view with mouse only.
can they be set to be turned on and off with a right click context menu?
then the preferences file could remember the state.
thanks,
Hamish
ps- any thoughts on the usefulness (or not) of the multi-display window
tiling patch attached to this ticket?
Cpu: All |
Comment(by wenzeslaus):
Replying to [comment:4 hamish]:
I like the idea but I remember when I was looking at the code in the
patch, my conclusion was that a lot of work is still required. Moreover,
I'm afraid that it will be hard to do it generally, especially in cross-
platform manner, for example even the tiling functionality in Ubuntu's
Unity does not work perfectly and there are different limitations in
Ubuntu 12.04 and 14.04.
Hoverer, general tiling window managers might be pretty good option. The
advantage is that you can also layout things like a terminal window. I'm
attaching screenshot from from Ubuntu 14.04 (with Unity) where I've used
`Ctrl+Alt+1` for terminal, `Ctrl+Alt+7` for layer manager, and
`Ctrl+Alt+9` and `Ctrl+Alt+3` for map displays. Terminal and especially
layer manager are unnecessary long but it was actually quite useful for
long commands and long map names.
By the way, the screenshot shows also another Unity's feature, a search in
main menu (aka HUD). This started to work with Ubuntu 14.04 (I don't know
if because of updates in wxPython, wxWidgets, wxGtk or Unity itself). By
this I don't mean that that everybody should start using Ubuntu. My point
is that there are some system features which GRASS can benefit from.
(Cycling just GRASS windows instead of all using {{{Ctrl+`}}} is
advantageous too, by the way.)
Cpu: All |
Comment(by annakrat):
only.
