GDAL
June 15, 2013, 7:14am
1
#2006: install: extra $GISBASE/etc/wxpython/scripts/Makefile?
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: trivial | Milestone: 6.4.4
Component: Installation | Version: svn-develbranch6
Keywords: wxpython | Platform: Linux
Cpu: x86-64 |
I notice that $GISBASE/etc/wxpython/scripts/Makefile gets installed.
any reason to keep that?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2006> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
June 15, 2013, 12:12pm
2
Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:2006 hamish]:
gui/wxpython/Makefile does:
SRCFILES := $(wildcard compat/* icons/*.* scripts/* xml/*) \
Note that gui/wxpython/scripts/Makefile is redundant as
gui/wxpython/Makefile never recurses into the scripts directory, so
scripts/Makefile won't be used unless the user "make"s that directory
manually.
Also, many of those "*" wildcards could (and should) be changed to "*.py"
to avoid installing cruft such as editor backup files.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2006#comment:1> ;
GDAL
June 17, 2013, 9:38am
3
Cpu: x86-64 |
Comment(by hamish):
'*' changed to '*.py' for dirs which only have *.py in them done in trunk
and relbr6 with r56744,5, maybe expand to *.py *.html later.
minimal patch to take care of scripts/*.py done in relbr64 with r56757.
will backport the rest after the freeze.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2006#comment:2> ;
GDAL
May 14, 2015, 10:08pm
4
Component: Installation | Version: svn-trunk
Resolution: | Keywords: wxpython, compilation, Makefile
CPU: x86-64 | Platform: Linux
Changes (by wenzeslaus):
* keywords: wxpython => wxpython, compilation, Makefile
* version: svn-develbranch6 => svn-trunk
Comment:
I'm just looking to `dist...` after compilation not the result of `make
install` but the file (`etc/wxpython/scripts/Makefile` or now
`/gui/wxpython/scripts/Makefile`) is no longer there.
However there are Makefiles in directories of `g.gui.*` modules:
$ cd dist...
$ find . -name "*Makefile*"
./gui/wxpython/psmap/Makefile
./gui/wxpython/animation/Makefile
./gui/wxpython/dbmgr/Makefile
./gui/wxpython/tplot/Makefile
./gui/wxpython/rlisetup/Makefile
./gui/wxpython/gmodeler/Makefile
./gui/wxpython/mapswipe/Makefile
./gui/wxpython/timeline/Makefile
./gui/wxpython/iclass/Makefile
./gui/wxpython/vdigit/Makefile
Do we have some bad Makefile template somewhere?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2006#comment:3> ;
