#2010: r.in.wms2 fails to install on 6.x
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.4
Component: Addons | Version: svn-releasebranch64
Keywords: r.in.wms2 | Platform: Linux
Cpu: All |
Comment(by hamish):
Replying to [comment:3 turek]:
> Hi Hamish,
> thanks for the fixes. I have ported back to G7 most of them
I hope you found them useful, if they are bad you don't have to listen to
me, it's your module after all.
> So far the name of the o flag remains.
> In description of s flag there is written:
> Skip requests for fully transparent data
> I am not sure if it is correct description. If this flag is not
> present, the data are fetched also with transparent layer (if
> available). Otherwise you can use bgcolor param with this flag
> and specify color for these transparent areas.
I misunderstood it then, in one of the TWMS/r.out.kml script I have
somewhere it checks if the returned tile is all-white and skips
warping/mosaicking that so that part of the background becomes NULL not
255. Is the idea to make a complete rectangle instead of missing tiles in
the corners? I was wondering how the bgcolor option fit in. If that
supports standard GRASS colors you might consider adding:
#% gisprompt: old,color_none,color
so from the module GUI the user gets the color-picking tool.
> The o was chosen as abbreviation for opaque.
I prefer to avoid -o,-q,-v as option letters if there are others
available, since it is easy for users to confuse them with --o,--q,--v.
fwiw I also like to avoid -l, -1, and -I, but for certain-font reasons.
> Spaces between options are still kept, it seems more clear to me
> than one block of ~20 options. But it also can be changed.
shrug, author's choice; the convention elsewhere is compressed but it
doesn't change the running of the script at all so just cosmetic, and I
agree it gets a bit hard to read when there are many options. Don't fear
the whitespace.
a couple observations/wishes:
* wx: switching from 1.1.1 to 1.3.0 clears selection and resizes window
height?
* wx: how about being able to filter the list like the location wizard
has for projection type Search? (often the servers have 50+ layers to
search)
* support for png8 image format? (like qgis has)
* I get an error when BGCOLOR is unset, does the spec require it or just
a picky WMS server?
{{{ <ServiceException>
BGCOLOR incorrectly specified (0xRRGGBB format expected)
</ServiceException></ServiceExceptionReport>
* module gui: Interpolation type isn't part of the server request. ->
Optional gui tab?
Also, I'm seeing a unicode error vs. layer Title string in the 6.4.3svn's
r.in.wms1's wxGUI wrapper. It's not to do with r.in.wms2.py, so I'll post
that to the -dev ML.
regards,
Hamish
ps- the WMS/WFS I'm using to test with:
http://wiki.openstreetmap.org/wiki/New_Zealand/Imagery
Ticket URL: <https://trac.osgeo.org/grass/ticket/2010#comment:4>
