#2011: WxGUI, menu does not work at all (languages using double-byte characters)
Reporter: venkat | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.4
Component: wxGUI | Version: 6.4.3 RCs
Keywords: encoding, wingrass | Platform: MSWindows 7
Cpu: Unspecified |
Testing GRASS6.4.3RC3 on Windows7 and Windows8
Several of WX-Python menu give error as shown below.
For example,
a) start GRASS and display Raster image
b) choose r.colors (or others from raster pull down menu
c) Result is the error shown below
This may be same problem as OSGEO4W Track ticket#1380
Similar problem was fixed in GRASS-6.4.2 but has crept in
again in GRASS-6.4.3RC2, GRASS-6.4.3RC3
-------- error message TO -------
File "C:\OSGeo4W\apps\grass\grass-6.4.3RC3\etc\wxpython\lm
gr\frame.py", line 541, in GetMenuCmd
input = GUI().GetCommandInputMapParamKey(cmdlist[0])
File "C:\OSGeo4W\apps\grass\grass-6.4.3RC3\etc\wxpython\gu
i_core\forms.py", line 1970, in GetCommandInputMapParamKey
p = re.compile('encoding="' + enc + '"', re.IGNORECASE)
NameError
global name 're' is not defined
-------- error message FROM -------
(ticket is for osgeo4w, not the standalone installer)
for the stand-alone nightly build of 6.4.3svn, re.py is there in
C:\Program Files\GRASS...\Python27\Lib, and imports ok in the python shell
tab of the layer manager. r.colors and the r.colors interactive wrapper
both open ok there.
I'm unable to test multi-byte language Windows, but seeing as the error is
`name 're' is not defined` my first guess is the missing re.py library.
Keywords: encoding, wingrass, osgeo4w | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by hamish):
try opening
C:\OSGeo4W\apps\grass\grass-6.4.3RC3\etc\wxpython\gui_core\forms.py in a
text editor, and adding the line "import re" about line 50 with all the
other import statements.
forms.py uses re.() but never imports it. I guess it is not always a
built-in?
Cpu: Unspecified |
Comment(by venkat):
"import re" works in the python tab in the layer manager.
In fact, the problem is not only for r.colors but for
all the menu items from the "Raster" pulldown (r.distance,
r.buffer etc.).
Typing the command (r.colors, r,buffer etc.) brings up the
command panel without the error I reported. Problem is when
we select from the pulldown "Raster" menu.
