[GRASS-dev] [GRASS GIS] #2012: d.vect wx module GUI forgets column names
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: svn-trunk
Keywords: d.vect | Platform: Linux
      Cpu: x86-64 |
Hi, I notice if I add a new vector layer and in the symbol tab of the
d.vect pop up GUI I set the symbol size_col and rotation_col options to
column names, it works ok, but then if I go back to the vector layer ->
preferences and the symbol tab again the given column names are gone &
forgotten.
If I press apply or ok a second time the map re-renders and those settings
are lost.
happens in all branches, e.g. for any points map: cat, cat, and size=1.
(trying that for a line map [m.cogo import example] without a db
connection or cat number for the line ends up in a traceback error)
I also notice an error in trunk that the drop down menu for the column
names is empty, but I can manually type "cat" there and it works.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2012&gt;
      Cpu: x86-64 |
Comment(by annakrat):
Please test again, the column problem should be fixed. Please be more
specific about the other problems, include the traceback error.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2012#comment:1&gt;
Hi
I just downloaded the newest GRASS (7) version from svn in order to test the issue.
In the build process I get an error message:
"Errors in:
/data/src/grass70svn/man"
make in the man directory says:
"make[2]: `/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.gmodeler.1' is up to date.
VERSION_NUMBER=7.0.svn /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/tools/g.html2man.py /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/html/wxGUI.html /data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.1
/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/html/wxGUI.html:643:0: Error (IndexError('pop from empty list',)): <a href="wxGUI.components.html">wxGUI components</a><br/>
make[2]: *** [/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.1] Error 1
make[2]: Leaving directory `/data/src/grass70svn/man'
make[1]: *** [manpages] Error 2
make[1]: Leaving directory `/data/src/grass70svn/man'
make: *** [default] Error 2"
Any ideas?
Stefan
-----Original Message-----
From: grass-dev-bounces@lists.osgeo.org [mailto:grass-dev-bounces@lists.osgeo.org] On Behalf Of GRASS GIS
Sent: 4. juli 2013 13:25
Subject: Re: [GRASS-dev] [GRASS GIS] #2012: d.vect wx module GUI forgets column names
      Cpu: x86-64 |
Please test again, the column problem should be fixed. Please be more specific about the other problems, include the traceback error.
grass-dev mailing list
grass-dev@lists.osgeo.org
On Thu, Jul 4, 2013 at 2:23 PM, Blumentrath, Stefan <
Stefan.Blumentrath@nina.no> wrote:
Hi
the issue.
"Errors in:
"make[2]:
is up to date.
/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/tools/g.html2man.py/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/html/wxGUI.html
make[2]: ***
Error 1
Any ideas?
sorry, please try to update and compile again (r57012)
Anna
Stefan
column names
      Cpu: x86-64 |
Geat!
Now both compiling and d.vect in the wxGUI work (I mean I can choose the layers from the drop-down list and switch forth and back in the tabs and the layers option remains as I set it)!
Thanks!
Just to make sure that it happened on purpose:
The layers-option “-1” is now neither available in the drop-down list nor the default setting for the layers-option in d.vect…
Stefan
On Thu, Jul 4, 2013 at 2:23 PM, Blumentrath, Stefan <Stefan.Blumentrath@nina.no> wrote:
Hi
“Errors in:
/data/src/grass70svn/man”
"make[2]: `/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/man/man1/wxGUI.gmodeler.1’ is up to date.
/data/src/grass70svn/dist.x86_64-unknown-linux-gnu/docs/html/wxGUI.html:643:0: Error (IndexError(‘pop from empty list’,)): wxGUI components
make[2]: Leaving directory /data/src/grass70svn/man' make[1]: *** [manpages] Error 2 make[1]: Leaving directory /data/src/grass70svn/man’
Any ideas?
Anna
Stefan
Cpu: x86-64 |
Ticket URL: <https://trac.osgeo.org/grass/ticket/2012#comment:1>
      Cpu: x86-64 |
Comment(by hamish):
tested in trunk, now remembers size_col and rotation_column. thanks. drop
down menu and no-db issues also seem to be fixed.
during testing it's still printing a traceback error to the terminal
though:
(wxgui.py:3206): Pango-CRITICAL **: pango_layout_get_cursor_pos: assertion
`index >= 0 && index <= layout->length' failed
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/2012#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: d.vect
  Platform: Linux | Cpu: x86-64
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:2 hamish]:
drop down menu and no-db issues also seem to be fixed.
so I am closing this ticket as fixed
though:
assertion `index >= 0 && index <= layout->length' failed
Usually, this is harmless. It's not easy to fix this, so if you consider
this as a problem open a new ticket (with minor priority).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2012#comment:3&gt;
