GDAL
July 1, 2013, 8:53am
1
#2019: v.voronoi Segmentation fault
Reporter: DmitryKolesov | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version:
Keywords: | Platform: Unspecified
Cpu: Unspecified |
The next lines cause crash report:
echo "7414297.17458|6180640.72109|242
7414836.48276|6179963.8034|817
" | v.in.ascii in=- out=test_tmp x=1 y=2 cat=3 --o
g.region vect=test_tmp
v.voronoi -t in=test_tmp out=test_tmp_v --o
WARNING: Vector map <test_tmp_v> already exists and will be overwritten
Reading sites...
Voronoi triangulation...
Segmentation fault (core dumped)
The version GRASS GIS is
g.version -r
GRASS 6.4.3RC3 (2013)
Revision: 50937
Date: 2012-02-25 14:14:51 +0100 (Sat, 25 Feb 2012)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2019> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
July 1, 2013, 8:55pm
2
Cpu: Unspecified |
Comment(by hamish):
is it trying to make a triangle (with area==0) from two points? or were
those two points extracted from a larger map having the problem?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2019#comment:1> ;
GDAL
July 1, 2013, 8:56pm
3
Keywords: v.voronoi | Platform: Unspecified
Cpu: Unspecified |
Changes (by hamish):
* keywords: => v.voronoi
Ticket URL: <https://trac.osgeo.org/grass/ticket/2019#comment:2> ;
GDAL
July 2, 2013, 6:31am
4
Cpu: Unspecified |
Comment(by DmitryKolesov):
Replying to [comment:1 hamish]:
Yes, I tryed to create Voronoi diagram from 2 points. But I think
(probably wrong):
1) Voronoi diagram of 2 points is possible (the line splits the plain in
two half-planes)
2) In any case the module should print a message (the module crashes now).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2019#comment:3> ;
GDAL
July 25, 2013, 7:25pm
5
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:3 DmitryKolesov]:
were those two points extracted from a larger map having the problem?
(probably wrong):
two half-planes)
I agree, this should be possible, but the algorithm (basically written in
1992) does not support this. I guess that the algorithm also does not
support points lying on a straight line.
now).
Done for trunk in r57182.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2019#comment:4> ;
GDAL
September 6, 2013, 6:52pm
6
Cpu: Unspecified |
Comment(by mmetz):
(probably wrong):
two half-planes)
Right, the same applies to any number of points lying on a straight line.
Fixed in trunk r57610.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2019#comment:5> ;
GDAL
September 7, 2013, 12:21am
7
Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:5 mmetz]:
> line. Fixed in trunk r57610.
great, thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2019#comment:6> ;
GDAL
September 7, 2013, 12:25am
8
Cpu: Unspecified |
Comment(by hamish):
btw, if it is of interest, I've beeen playing around with some 3D grid
creation software lately called Gmsgh, (GPL>=2, standard debian/ubuntu
package)
http://www.geuz.org/gmsh/
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2019#comment:7> ;
GDAL
September 7, 2013, 12:26am
9
Cpu: Unspecified |
Comment(by hamish):
> called Gmsgh
sorry for the typo, make that "Gmsh".
apt-get install gmsh
Ticket URL: <https://trac.osgeo.org/grass/ticket/2019#comment:8> ;
GDAL
January 12, 2014, 7:20pm
10
Priority: normal | Milestone: 6.4.4
Cpu: Unspecified |
Changes (by neteler):
* milestone: 6.4.3 => 6.4.4
Comment:
For the record: fix r57610 (trunk) was backported to relbranch in r57820.
The original crash reported above no longer occurs. Can the ticket be
closed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2019#comment:9> ;
GDAL
May 5, 2014, 6:55pm
11
Type: defect | Status: closed
Component: Vector | Version: svn-releasebranch64
Resolution: fixed | Keywords: v.voronoi
Platform: Unspecified | Cpu: Unspecified
* status: new => closed
* version: => svn-releasebranch64
* resolution: => fixed
Comment:
Replying to [comment:9 neteler]:
closed?
Closing as fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2019#comment:10> ;
