#2020: r.volume gives wrong results on G7
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Component: Raster | Version: svn-trunk
Keywords: r.volume | Platform: Linux
Cpu: x86-64 |
Comment(by madi):
Nikos, thank you for testing. I had made several try, I must have exported
a couple of maps that don't match with the result that I reported, but
still the results between G6 and G7 are different.
Thanks, madi
Cpu: x86-64 |
Comment(by hamish):
The problem is with the handling NULL cells in the input map, or rather
not handling them. It's this line in main.c: `sum[i] += data_buf[col];`
Every now and then the value which is added is -2147483648 instead of in
the range of ~ 0-36. That happens when the clump map exists but the input
map does not. So for your test data the slope map is 1 cell smaller than
the basins map around the edges of the area, and those cells which are
non-NULL in the basins map but NULL in the slope map return corrupted
values.
fwiw between devbr6 and trunk there don't seem to be any module changes
beyond the conversion of G_() to Rast_() in the function names.
I notice even in grass7 it's still trying to make an old grass5 sites_list
points map, and also that the input map is always opened and read as a
CELL map, even when it is floating point, so the results will be.. less
correct than they might otherwise be due to rounding/quantization errors.
For 0.0-1.0 normalized data that might be fatal. (conversion of the input
to int(map*1000) with r.mapcalc gives the same error for NULLs in 'sum'
though)
Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:3 hamish]:
values.
sites_list points map, and also that the input map is always opened and
read as a CELL map, even when it is floating point, so the results will
be.. less correct than they might otherwise be due to
rounding/quantization errors. For 0.0-1.0 normalized data that might be
fatal. (conversion of the input to int(map*1000) with r.mapcalc gives the
same error for NULLs in 'sum' though)
NULL handling fixed and fp support added to r.volume in trunk r56984.
Cpu: x86-64 |
Comment(by madi):
Hello Markus,
Thank you for that! Actually I still find that the results produced by G7
are different from the ones produced by G6. For the dataset attached,
(setting the region to match slope), i get:
From G7:
Volume report on data from slope using clumps on basin map
Cat Average Data # Cells Centroid Total
Number in clump Total in clump Easting Northing Volume
Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:5 madi]:
> Hello Markus,
G7 are different from the ones produced by G6.
This is because r.volume in G7 has now floating point support and the
slope map in your sample data is single precision floating point, thus
correctly read only in G7. You can now file a bug for r.volume in G6.
Cpu: x86-64 |
Comment(by hamish):
we may as well continue with this ticket since it isn't too complicated.
Is it ok to open a CELL map as DCELL in grass6, or do we need a switch
statement to use the correct read/isnull commands?
if skipping adding to sum because of a null, don't we need to 'count--'
too? or else for the average sum/n has too big an n.
Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:7 hamish]:
I think it is ok to open CELL or FCELL maps as DCELL in grass6, IIRC
various modules do so already.
Right, fixed in r56987.
