[GRASS-dev] [GRASS GIS] #2025: r.kappa: output file saving error on Windows
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Raster | Version: svn-releasebranch64
Keywords: r.kappa | Platform: MSWindows 7
      Cpu: Unspecified |
winGRASS users report that they are unable to save the error
matrix and kappa to a file.
Feb 28, 2013 Rebecca wrote:[[BR]]
I have tried both with the GUI and in python script.[[BR]]
I am running it using NX client and so my file paths have '\' symbols to
represent directories. When I use the 'browse' icon to locate the correct
directory/file, grass automatically uses '\'. However I am receiving the
error msg:
Illegal filename. Character </> not allowed.
For a similar report, see also:
http://fromgistors.blogspot.it/2013/07/classification-error-QGIS.html (at
page bottom)
Random ideas:
There must be something lacking in the ask() function:
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/gis/ask.c#L345
Perhaps a Windows specific directory separator is needed,
similar to
http://trac.osgeo.org/grass/changeset/55135/grass/branches/releasebranch_6_4/lib/g3d
Ticket URL: <http://trac.osgeo.org/grass/ticket/2025&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:2025 neteler]:
This was fixed in 7.0 with r32820. I suggest back-porting.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2025#comment:1&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:1 glynn]:
Done in r57045,6.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2025#comment:2&gt;
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:2 mmetz]:
> Done in r57045,6.
I have made a patch of r32820, diff against relbranch64 attached (recent
r.kappa
fixes already excluded from r32820 backport).
Please verify the attached diff. It compiles on my (Linux) machine.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2025#comment:3&gt;
      Cpu: Unspecified |
Replying to [comment:3 neteler]:
r.kappa
It additionally requires:
svn rm raster/r.surf.fractal/interface.c
Ticket URL: <http://trac.osgeo.org/grass/ticket/2025#comment:4&gt;
      Cpu: Unspecified |
Comment(by mmetz):
> > Done in r57045,6.
r.kappa
G_legal_filename() is meant for GRASS data file names (anything in
$GISDASE/$LOCATION_NAME/$MAPSET/<element>/, therefore your patch does not
make sense.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2025#comment:5&gt;
      Cpu: Unspecified |
Replying to [comment:5 mmetz]:
> in $GISDASE/$LOCATION_NAME/$MAPSET/<element>/, therefore your
> patch does not make sense.
So you mean that the original r32820 doesn't make sense? I just
prepared a backport patch...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2025#comment:6&gt;
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:6 neteler]:
The original r32820 makes sense because in this case the output is a file
anywhere on the file system.
GISDASE/$LOCATION_NAME/$MAPSET/<element>/, not for output files located in
a user-defined folder.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2025#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.kappa
  Platform: MSWindows 7 | Cpu: Unspecified
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
OK no problem, proposed backport of r32820 deleted.
The original ticket is solved anyway, closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2025#comment:8&gt;
Comment(by glynn):
Replying to [comment:7 mmetz]:
It's meant for anything which will be a single component of a pathname:
either an unqualified map name, or a mapset name, or a location name.
Any characters which have "meaning" to GRASS or to the OS are not "legal"
in this sense, so it rejects names which contain e.g. "@" (mapset
separator) or "/" (directory separator).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2025#comment:9&gt;
G_legal_filename() cleanup patch (backport from G7) for GRASS 6 moved to
ticket #2031
Ticket URL: <http://trac.osgeo.org/grass/ticket/2025#comment:10&gt;
