[GRASS-dev] [GRASS GIS] #2034: GUI crashes on launch for newly compiled binary for Mac OS X
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: MacOSX
      Cpu: OSX/Intel |
Beginning several months ago, with the introduction of the new toolbox,
GRASS 7 GUI crashes on launch--after selecting a working location/mapset
and after the splash screen. the immediate cause of the crash is that
..xml/menudata.xml is empty.
The reason that menudata.xml is empty is that make xml/menudata.xml fails
during compilation. It fails with a bogus error of "No module named
wxversion".
Here is the error:
make /Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-
darwin12.4.0/etc/gui/wxpython/xml/module_items.xml
Generating interface description for all modules...
GISRC=/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-
darwin12.4.0/demolocation/.grassrc70
GISBASE=/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.4.0
PATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-
darwin12.4.0/bin:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-
darwin12.4.0/bin:$PATH"
PYTHONPATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-
darwin12.4.0/etc/python:/Users/Shared/grass_dev/grass7_dev/dist.x86_64
-apple-darwin12.4.0/etc/python:$PYTHONPATH"
DYLD_LIBRARY_PATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-
darwin12.4.0/lib:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-
darwin12.4.0/lib:" LC_ALL=C python tools/build_modules_xml.py >
darwin12.4.0/lib:" LC_ALL=C python core/toolboxes.py > xml/menudata.xml
ERROR: wxGUI requires wxPython. No module named wxversion
make[4]: *** [xml/menudata.xml] Error 1
make[3]: [default] Error 2 (ignored)
A little background:
1. I am compiling on OS X 10.8 (Mt. Lion) with some special hacks so that
the binary works with OS X 10.6 (Snow Leopard). All Mac binaries are
compiled with wxPython bundled in the binary so that there is no conflict
between the version use for compiling and the version on a user's
computer. This has worked fine for over a year.
2. Beginning in the fall of 2012, I started getting errors during
compilation from a series of new modules that share some new gui classes,
including mapswipe, cartographic composer, etc. BUT, these modules work
fine in spite of the compiler errors. I mention these because the cause of
these errors may be related to the problem in this report.
The crash reported here seems to be associated with the new toolbox
module. Glynn thinks that it may be a ctypes problem. He notes:
"It seems to start going wrong with lib/python/ctypes, specifically:
darwin12.4.0/lib:" LC_ALL=C ./ctypesgen.py --cpp "gcc -E
-I/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-
darwin12.4.0/include -I/Users/Shared/grass_dev/grass7_dev/dist.x86_64
-apple-darwin12.4.0/include -D__GLIBC_HAVE_LONG_LONG" -lgrass_gis.7.0.svn
darwin12.4.0/include/grass/gis.h
darwin12.4.0/include/grass/defs/gis.h -o OBJ.x86_64-apple-
darwin12.4.0/gis.py
Status: Preprocessing
/var/folders/dm/x_m7msz48xj_9c0059b59rf00000gn/T/tmpH5wFMB.h
Status: gcc -E -I/Users/Shared/grass_dev/grass7_dev/dist.x86_64
darwin12.4.0/include -D__GLIBC_HAVE_LONG_LONG -U __BLOCKS__ -U __GNUC__
-dD "-Dinline=" "-D__inline__=" "-D__extension__=" "-D_Bool=uint8_t"
"-D__const=const" "-D__asm__(x)=" "-D__asm(x)=" "-DCTYPESGEN=1"
"-D__uint16_t=uint16_t" "-D__uint32_t=uint32_t" "-D__uint64_t=uint64_t"
Error: gcc -E -I/Users/Shared/grass_dev/grass7_dev/dist.x86_64
darwin12.4.0/include -D__GLIBC_HAVE_LONG_LONG: In file included from
/usr/include/stdio.h:64,
darwin12.4.0/include -D__GLIBC_HAVE_LONG_LONG: from
darwin12.4.0/include/grass/gis.h:24,
/var/folders/dm/x_m7msz48xj_9c0059b59rf00000gn/T/tmpH5wFMB.h:1:
/usr/include/sys/cdefs.h:81:2: warning: #warning "Unsupported compiler
detected"
Status: Parsing
Error: /usr/include/stdio.h:252: Syntax error at '__attribute__'
Error: /usr/include/stdio.h:252: Syntax error at 'i2'
I'm wondering if it's trying to use headers written for gcc with
clang, or vice versa.
In any case, if lib/python/ctypes fails, any Python modules which
import modules from grass.lib will fail."
This is where we are right now.
There is a workaround, found by Anna.
1. start GRASS 7
2. in the terminal, cd to ../gui/wxpython
3. run: python core/toolboxes.py > xml/menudata.xml
4. then you can start the GUI with g.gui
William Kyngesburye reports that he has no problem if he compiles with
wxPython 2.9 and Python 2.7. I'm using wxPython 2.8.12 and Python 2.6 for
backward compatibility, but there should not be any code specific to
wxPython 2.9 or Python 2.7 in the relevant modules. Also, I tried
compiling with new Python and wxPython and still got errors.
Anna, Glynn--and I--think this is a deeper problem (maybe in ctypes code
or implementation) that probably affects other things but that is not
causing a crash.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2034&gt;
      Cpu: OSX/Intel |
Comment(by mlennert):
What is the status of this bug ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2034#comment:1&gt;
      Cpu: OSX/Intel |
Comment(by cmbarton):
This was still the case for me when I last compiled GRASS 7 a couple weeks
ago. There have been some changes since which may or may not make a
difference. I'm traveling this week and tied up the first half of next
week. I might be able to do a test tomorrow, but would not count on it.
Otherwise, I can compile and test again when I have a more time in a
couple weeks..
Michael
Ticket URL: <https://trac.osgeo.org/grass/ticket/2034#comment:2&gt;
      Cpu: OSX/Intel |
Comment(by annakrat):
I don't think any recent changes are related.
A few days ago I compiled GRASS 7 on Mac 10.8 with wxPython 2.8 and I had
problems only with the 32/64 architecture (which I expected and solved by
setting VERSIONER_PYTHON_PREFER_32_BIT=yes) and other problems (r57536,
r57537). None of these problems is related to the issue described here.
So it could be related to the 'special hacks' you do to make the binary
work with Mac 10.6, or there is some mess in your python/wxPython
installation (I had similar problems myself when I upgraded to newer
Ubuntu version) and another possible reason is some hidden problem in
GRASS. Probably it's a combination of these problems.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2034#comment:3&gt;
      Cpu: OSX/Intel |
Comment(by wenzeslaus):
To summarize:
The discussion [http://lists.osgeo.org/pipermail/grass-
dev/2013-May/063806.html GRASS 7 crashes on startup on Mac] ([http
://osgeo-org.1560.x6.nabble.com/GRASS-7-crashes-on-startup-on-Mac-
td5052981.html nabble]) contains a workaround to get rid of the
`menudata.xml` error which is mentioned in the ticket.
dev/2013-August/065381.html no more GRASS 7 for Mac] ([http://osgeo-
org.1560.x6.nabble.com/no-more-GRASS-7-for-Mac-td5071809.html nabble])
extends the workaround because now there is a more than one file of that
type (generated `menudata.xml` from toolboxes files).
dev/2013-August/065482.html Mac OS 10.8: g.gui and DISPLAY]
([http://lists.osgeo.org/pipermail/grass-dev/2013-August/065482.html
nabble], originally named as "Max OS 10.8: g.gui and DISPLAY") mentioned
before and revisions r57536 and r57537 are important but unrelated to this
ticket.
The unrelated discussion [http://lists.osgeo.org/pipermail/grass-
dev/2013-September/065566.html Resources about compiling on Mac OS X]
([http://osgeo-org.1560.x6.nabble.com/Resources-about-compiling-on-Mac-
OS-X-td5076035.html nabble]) contains a detailed description of the
workaround.
cmbarton on ML:
Seem like this needs to be done in the GRASS-7.0.app. So you have to run
bindist first.
Then launch GRASS 7. The GUI will crash.
From the GRASS command line, cd to the ../gui/wxpython directory inside
the GRASS-7.0.app and run...
python core/toolboxes.py "module_tree" > xml/module_tree_menudata.xml
Next, copy the newly created menudata.xml and module_tree_menudata.xml
files back into the binary distribution (in ../dist.x86_64-apple-
darwin12.4.0) and rerun bindist to make a new GRASS-7.0.app and *.pkg.
The reasons for and connections between the `menudata.xml` error (not
compiled XML file) and ctypes `__attribute__` error are still unclear. We
only know that you can get the `__attribute__` error and ''not'' get
`menudata.xml` error (tested on Mac OS 10.8) at the same time.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2034#comment:4&gt;
      Cpu: OSX/Intel |
Just tested. Still broken. Workaround still works.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2034#comment:5&gt;
Component: Compiling | Version: svn-trunk
Keywords: wxGUI, Python, toolboxes, ctypes | Platform: MacOSX
      Cpu: OSX/Intel |
Changes (by wenzeslaus):
  * keywords: => wxGUI, Python, toolboxes, ctypes
  * component: wxGUI => Compiling
Comment:
The creation of toolboxes files can be made less vulnerable by
implementing enhancement #2142. However, the error toolboxes error with
two step compilation workaround is not caused by creation of toolboxes
itself but probably by compilation (or environment during compilation).
Note that it happens not only for Mac OS X but sometimes for some Ubuntus
too (but the circumstances are unclear, it can happen when preparing
package for PPA in Launchpad). See [http://lists.osgeo.org/pipermail
//grass-user/2013-October/069082.html G7-gui and G64 add-on problems on
Xubuntu (installation from grass/ubuntugis ppa)] ([http://osgeo-
org.1560.x6.nabble.com/G7-gui-and-G64-add-on-problems-on-Xubuntu-
installation-from-grass-ubuntugis-ppa-td5084261.html nabble],
[http://comments.gmane.org/gmane.comp.gis.grass.user/48244 gmane]).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2034#comment:6&gt;
      Cpu: OSX/Intel |
I haven't had problems recently with compilation on Mac, perhaps this
r60007 fixed that? It is already backported. Can we close this ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2034#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wxGUI, Python, toolboxes, ctypes
  Platform: MacOSX | Cpu: OSX/Intel
Changes (by cmbarton):
  * status: new => closed
  * resolution: => fixed
Comment:
AFAICT, this has been fixed in the current versions of both 7.1 and 7.0
svn. So I can think we can close. Thanks much.
Closing.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/2034#comment:8&gt;
