#2042: wxgui: no more menu access to r.in.gdal / v.in.ogr
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: r.in.gdal, v.in.ogr, gui
Comment (by mlennert):
Replying to [comment:24 martinl]:
> Replying to [comment:23 mlennert]:
> > I don't agree. I don't think the wizard should replace the module GUI.
It should make initial use easier and by that cover a large majority of
use cases, but why program a whole new wizard interface which at the end
replicates the GUI module.
> it's not a wizard, it's GUI front-end for r.in.gdal/v.in.ogr module
which enables to call this module in the loop, nothing else.
Call it what you want. I actually like the idea of calling it a wizard as
it simplifies a series of things, such as selecting layers in a file or in
a database, that demand a more advanced knowledge to do directly in the
modules.
In any case, it is a simplified interface for importing data via
r.in.gdal/v.in.ogr. And most people use it not only for looping but for
any import, as this is what they get when they chose file import from the
menus.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2042#comment:25>
