#2042: wxgui: no more menu access to r.in.gdal / v.in.ogr
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: r.in.gdal, v.in.ogr, gui
Comment (by mlennert):
Replying to [comment:26 martinl]:
> Replying to [comment:25 mlennert]:
> > Call it what you want. I actually like the idea of calling it a wizard
as it simplifies a series of things, such as selecting layers in a file or
in a database, that demand a more advanced knowledge to do directly in the
modules.
> try v.in.ogr dialog (--ui) in trunk, it allows you the same (except of
importing several layers in the loop).
Could you explain where this dialog comes from ? AFAIU, it is not the
automatically created dialog based on the parser, or ? So even the --ui
doesn't even give the normal interface anymore ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2042#comment:27>
