#2042: wxgui: no more menu access to r.in.gdal / v.in.ogr
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: r.in.gdal, v.in.ogr, gui
Comment (by martinl):
Replying to [comment:27 mlennert]:
> Could you explain where this dialog comes from ? AFAIU, it is not the
automatically created dialog based on the parser, or ? So even the --ui
doesn't even give the normal interface anymore ?
the dialog is still autogenerated, the only difference is that for
gisprompt 'datasource' is used GDALSelect widget (1), so nothing special
in forms.py. BTW, by normal interface do you mean just textctrl? It's was
not normal, it was just not designed at all. You needed to type full path
to the file, directory, or connection string manually. I don't feel it as
normal in the sense of (interactive) GUI. GDALSelect should be improved of
course, but it is separate issue.
(1) source:grass/trunk/gui/wxpython/gui_core/forms.py#L1689
Ticket URL: <https://trac.osgeo.org/grass/ticket/2042#comment:28>
